Fuel filter for 863
/ Fuel filter for 863 #1
mtk51
Bobcat 863
The BobCat started running rough yesterday and I suspect the fuel filter. The dealer won't be open until Monday.
Tractor Supply Co. listed a Fram C1191A for the 863. I'm new to BobCats and haven't had the filter off yet, but this one doesn't look right. It is not a spin-on and doesn't have a drain at the bottom. It does have a hole through the middle of the filter.
Anyone know a 3rd party filter that will work?
How do I bleed the fuel line after replacing it?
ALSO
Anyone recommend a fuel additive to clean the injectors?
Mark
/ Fuel filter for 863 #2
Napa 3192 will work, I have used hundreds of them. Here is the link to Napa Filters
To bleed after changing, loosen the bleeder screw on top of the filter housing, pump the primer bulb until you get a steady stream of fuel out of the bleeder, tighten the screw, pump the bulb a couple more times for good measure, start the machine.
Brian
Thanks. That one looks more like it.
I think the primer bulb has fozzilized. Probably better find one of those also.
It's 2 degrees here this morning.
Never volunteer to take over a farm in the middle of winter.
Mark
/ Fuel filter for 863 #4
if you fill the new filter all the way full before installing, you shouldnt have to bleed. i bet i havent had to bleed 10 out of the 1000s of bobcat fuel filters ive changed
Changing the filter didn't help.
Replacing the primer bulb solved the problem.
Must have cracked and been sucking air.
Employee called from the farm yesterday and said the Bobcat is running rough again and exhaust is pretty black.
Any suggestions before I call for service?
/ Fuel filter for 863 #7
Black smoke is caused by the engine being over-fueled, or under-aired. I would check the air filter first. If the inner air filter is discolored at all, it needs to be replaced, it will plug up much faster than the outer filter. If just the outer filter is clogged you can knock the dirt out of it by tapping in on something. I don't recommend blowing it out, you can open the pores or damage the filter.
Brian
Brian
Would pulling the filters out be a good test to see if that is the problem?
I wouldn't do any work without them in, but was wondering if that would be a good test.
The outer filter looked dirty, but not bad. The inner one looked OK. But it was below zero when I looked at them a few days ago.
I'm going out to the farm this afternoon to take a look at it. Also hope to get a new radiator into the Ford tractor so the Bobcat doesn't have to do everything.
/ Fuel filter for 863 #9
Yes, pulling the filters would be a good quick check.
Brian
No change with the filters out.
Just before the fuel filter is another "part". I removed the cover and found a round metal screen. It was covered in black, gooey junk. I cleaned it off, screwed the cover back on and the Bobcat is running great
Is that some sort of prefilter?
/ Fuel filter for 863 #11
It must be, but it is not factory.
Brian
/ Fuel filter for 863 #12
Brian
It is very much so FACTORY! That is the screen inside of the lift pump? Please give the man the correct info!:eek:
/ Fuel filter for 863 #13
Sorry I didn't think the "part" he was talking about was the lift pump. The way I read it was that it was an aftermarket filter he was disassembling. The lift pump is after the filter.
Brian
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2 BALE HAY SPEAR (A63291)
2 BALE HAY SPEAR...
