Oil & Fuel Fuel cans
/ Fuel cans #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Like the no-spill diesel fuel containers. Even my wife can fuel the little tractor but doesn’t like to. The bad part was holding the button down. 5gallons took 2-3 minutes to drain. Added these vents.
ZOOYL Gas Can Vent Caps Retrofit Kit 6 Packs, Enhances Flow for Faster Refills, Universal Fuel Tank and Gas Can Replacement Vent Valve Made of Durable Stainless Steel with Attached Silicone Rubber Cap https://www.amazon.com/dp/B08VH2ZL1...abc_T7P0EXR2HVQBDW8NV2R8?_encoding=UTF8&psc=1
Now can drain 5 gallons in 30-40 seconds. Not a single drop spilled.
Also retrofitted some jugs for the bigger tractor.
Had a bulk tank for awhile when farming more. Maintenance, filters, additives, draining, algae all cost time and money too. Use 80-100 gallons per year lately. Went back to jugs. Maybe switch to 55gallon drums? Hoisting jugs is kind of a barometer to keep tractoring.
What ever bulk tank you use, a pressure/vacuum vent is necessary for storing fuel around here. Keeps your fuel dryer. Surprised how many tanks I see with just a rain drip vent.
/ Fuel cans #3
Still looks to be too heavy for me. I've taken to doing it 2 gallons at a time.
With 5 gallon container, I first sit it on the hood and put a syphon in it to take most of it out before pouring the last in.
/ Fuel cans
But does the NO-Spill still shut off with added can vent as its designed to do with spout vent?
That’s a good question. It’s so controllable I have no trouble filling to the top without spilling with or without the vent. Haven’t challenged if flow would stop at nozzle.
/ Fuel cans #5
I put the can in the bucket, raise it as high as I can reach, then run a siphon hose into the tank.
/ Fuel cans #6
I’ve never had any luck with the no spill shutting off as claimed. You just have to let off the button.
/ Fuel cans #9
This is what I have:
/ Fuel cans
There are some new nozzles that are absolutely impossible to use without spilling. Have retrofitted some old and new jugs to large flexible nozzles readily available. Maybe not legal in some states but not spilling fuel is important to me. The particular brand of jug in the picture works good for the smaller tractor. Two handle design helps lifting.
Not having to support the jug till most of the fuel is transferred helps my old joints.
/ Fuel cans #12
i prolly have 10 no spills, they work fine, I agree they don't shut off consistently. When I got the tractor i bought one of these since my fill neck is on the hood. I rest it on the steering wheel and just wait.
/ Fuel cans #13
Eagle Safety Cans and done.
I’ve used those and they don’t have many good options to rest the can while they’re pouring and the funnel is a hassle to have to clean every time.
/ Fuel cans #14
I've quit "pouring" out of cans altogether.
I bought D cell powered pumps, they shut off when the fuel tank is full, so I can sit the can on a rag on the hood, turn on the pump and walk away.
I don't need to buy spl. fuel cans either, I use the empty 2-1/2 gallon jugs my Rotella oil comes in. At 2-1/2 gallon size, they are easy to lift up on the hood too.
SR
/ Fuel cans #15
i'm surprised your gas station lets you fill up your "oil jugs" with diesel. you must know somebody :)
/ Fuel cans #16
I have one of those. Hate it. Trying to hold the 5 gal can while you push and hold down that spring button while fuel SLOWLY gurggles away. I like my VENTED VIP Racing can.
/ Fuel cans #17
I pump 2 gallons out of my diesel generator's 60 gallon tank. Then put back when I get it down about 20 gallons.
/ Fuel cans #18
I gave up on lifting 5 gallon jugs. Too old, too heavy, unwieldly trying to hold up. Found a new 55 gallon drum and installed a standard home heating fuel oil fill and vent on it. Used a 12volt Amazon 'special' diesel pump kit that included the pump, hose, handle and input hose and strainer. It pumps at about 15gpm. Mounted it on a nice drum dolly that really rolls easily! I replaced the cord and large alligator clips with a 20' cable and a connector that mates with one I put on the fel cross support.
At my age I really enjoy the little things!
/ Fuel cans #19
I only use about 200 gallons per year so I like the 5 gallon No-Spill cans. Yes a couple hundred gallon barrel with a electric pump would be nice but then you have other issues to deal with.
/ Fuel cans #20
You must live in a **** state if they even look what you’re pouring fuel into.
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2017 International 4300 Box Truck (A62613)
2017 International...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
John Deere 4955 Tractor (A66285)
John Deere 4955...
2022 EZ-GO ELITE...
Kubota M6950 (A64127)
