And Triple-tractor BrowN (TBN),
I like your set up but .
1*you would have to schlep the yellow jugs around to fill those monsters up--.
2*I got one of those scepter flo 'n go pumps and I just set my diesel can up on a ladder to fill up.
*Yeah home delivery.LBrown: How do you fill the big drum?
*Home delivery pumped into your drum?
Cloud points(assuming no biodiesel)for #2 is maybe 5-6F.
Just so you will know, the cloud point on #2 diesel is +40F
smfcpacfp:Respectfully sir,it is my belief you're misinformed on the cloud point of #2 diesel fuel.I've never seen ULSD cloud point listed at the terminals we load at over +8F.Think about it,you'd be on the verge of gelling before water would freeze.Anyhow,great buying opportunities on the market yesterday,eh!Good Day.
My fuel filter gelled the other day and I was using double doses of Power Service. It was sub-zero a few days prior and the tractor sits in an unheated pole barn. I just bought some Howe's diesel treat and will see how that fares.
Check out this .pdf from The Diesel Place web site. I now use Opti-lube. I hope I attached the document correctly.
Can you use karosene w/a treatment and is it cheaper w/o the road tax ?
I worked at a gas station in highschool and people tried to pump it right into their VW's .
I've been running diesel powered trucks for a few decades.
Initially I would dutifully slop in all kinds of recommended additives, but other than buyer's remorse they gave me nothing in return.
These days I just load up at truck stops where they turn over a lot of fuel, the mix is seasonally adjusted, plus a safety margin.
I am not having truck problems.
I get my tractor fuel at a similar place, less than 2 miles from the house, but he turns over a good quantity of fuel, so it is fresh.
I am not having tractor problems.
There is another recent thread where folk are be-moaning the fact that they are having cold start problems DESPITE having twice the recommended doses of xy_whatever.
For some odd reason they seem to be going for even more of what isn't working for them (puzzled).
Basically additives are hokum, OK snake oil.
Drain the glass bowl FREQUENTLY, change filters, fill up ONLY where they sell a lot of fuel and take care of their in-ground tanks.
Don't get snow in your tank if you fill from 5 gallon jugs.
Either there isn't a problem or additives aren't the solution.
Just thought I would post my recent experience...I started up my BX2350 at about +20F. It ran fine for about 2 minutes, before starting to studder and eventually dies. Try to restart, and it wants to, but not enough fuel. So I start thinking what could be wrong, never had a problem before. Call my dealer and he says it sounds like the fuel is gelling, first time I have heard of diesel fuel gelling(my first and only diesel). He suggests that I get some 911, add it to the tank and remove the fuel filter and 911 to it.
So I get the Power Service 911(32oz bottle for $7.99). And thought I would also get some fuel treatment since the 911 is only for emergency situations, got the Power Service version also. Since the next day was suppose to be above freezing, I thought I would just add some 911 and the fuel treatment to the tank and wait for tomorrow to come so the sun can warm it up a little. Waited til the afternoon, went out and it started right up. Used it for about 30 minutes to plow, put it away and haven't had a problem since.
Good read. I see that Power Service is at the bottom of the list. And that 2-stroke oil is better.
