Oil & Fuel Fuel additives for diesel?
   / Fuel additives for diesel? #1
wjoerob
Franklin IN
Kubota 6100
:confused: I know it's good to add Sta-bil to gasoline in cans or in mowers, etc. But is there a similar product for diesel? I have an older model B6100 'Bota. Several people around central Indiana had problems in the -12 degree weather the other day, with their diesel gelling up. Some guys managed to get their trucks started, got out on the road, and then they died just a couple of miles from home.
   / Fuel additives for diesel? #2
   / Fuel additives for diesel? #3
I have used Power Service for the last 8 years in my tractors and I have never had a problem. I get my diesel in 5 gal containers and when I get them home I just put a little in. I always add some, summer or winter, having the older machines. I don't measure it, but I figure I am putting a few oz. in. I plowed my driveway last Fri. (I think it was around 15 deg. F) and my tractor sits in an unheated pole barn and doesn't have a block heater and it started right up almost as if it were 70 deg. out. The only thing was I ran the glow plug preheat for about 20 sec. which I normally only run it for about 2-5 sec. I will be honest this is one of the major benifits of a new tractor. It would have taken a little more effort to get the old B7200 started, but it has always started as well before in the winter when I used it to plow with.
   / Fuel additives for diesel? #4
I use Power Service year around never had a problem. A32oz. bottle last me a long time.
   / Fuel additives for diesel? #5
I add the Power Service to the fuel can BEFORE I fill it this way the fuel mixes with the Power Service while I fill. Nothing like getting two things done at the same time. :D
   / Fuel additives for diesel? #6
My fuel filter gelled the other day and I was using double doses of Power Service. It was sub-zero a few days prior and the tractor sits in an unheated pole barn. I just bought some Howe's diesel treat and will see how that fares.
   / Fuel additives for diesel? #7
Best way to avoid fuel gelling is to use #1 diesel which starts to gel at -40F (cloud point). The problem is that it doesn't have good lubricating properties and it doesn't have as much energy per gallon.
I use Opti-Lube XPD as an additive. The last time I saw independent rating of diesel additives, this was rated #1, unfortunately the distributorship is limited, so I ordered it on line. It is also pretty expensive. It also suposedly reduces the cloud point as do most additives, but I have yet to see any cloud point effect figures for any additives, so I use #1.
If #1 starts gelling you would be best to stay inside and bundle up.:D
   / Fuel additives for diesel? #8
I bought my first tractor almost 5 years ago. A BX2200. On another board that I visited before finding this one most seemed to recommend Power Service. Bought a bottle at Wal Mart and always pour "some" in the 5 gallon container before I pour it into the tractor. Have done this on my BX2200, BX1500, B7800, and now BX2350 and L3240HST and will get a bottle for my F2880E which I keep at another location. I don't use it for cold weather. Not enough snow to plow so I'm sure not going to be out on my tractor when it's cold. Wellll, actually I did get the B7800 out one time when it was really cold. I had a friend doing some front end loader work for me. He came one morning and couldn't get the loader off his trailer. The tracks were frozen. He used to kid me about my little Kubota. I told him I could pick up his loader with my Kubota but never had to prove it to him.:) Well, the day his tracks froze he tried everything to free them with no luck. He finally told me to go get my Kubota and bring it down to the trailer. I knocked his tracks loose from the side with the front bucket which loosened them enough for it to drive off the trailer. He never said much after that about my "little" Kubota but I did kid him about it taking a Kubota to get a CAT moving.
   / Fuel additives for diesel? #9
Hello
I use howes lubricator in my b-7800 have had it for 5 yrs with no gel ups in RI
   / Fuel additives for diesel? #10
I am curious what the difference is in our situations. I checked and it was -13 deg. F that morning (1-16-09) at like 8am and I got the tractor out around 2pm when it had warmed up to about 15 deg.F. The warmest it got the day before was 8 deg.F. I was wondering what kind of diesel you use. I use off road/Ag (red) from my local Co-op. I wonder if they have something added to it as well. I just thought about it, I believe the diesel in my tractor right now I bought back in the fall well before it was even close to getting cold out.
2003 Big Tex 10PI...
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2018 Toro Workman MDX Utility Cart (A56857)
2018 Toro Workman...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2014 Walker Compactor (A55787)
2014 Walker...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56435)
2020 John Deere...
