FRONT WHEELS LOCKING UP
/ FRONT WHEELS LOCKING UP #11
Neat information!! I do not have a manual what else can you do with programming?
/ FRONT WHEELS LOCKING UP #12
I have been having issues with my 2003 Toolcat as well
My front wheels are not turning at the same speed as the rear
One thing i did notice was if i put the machine in axle match mode the front wheels would only turn a couple inches and then lock
When its out of axle match is will spin but in my opinion its not spinning at the correct speed to match the rear
When in reverse all 4 spin at the same speed (reverse functions as it should)
Been having issues with forward for over a year off and on have unplugged the rear wheel sensor and did nothing
Have replaced the front speed sensor and it didn't fix it
I have replaced the solenoids on the pumps and one of the solenoid stems (might have been bad but since this keeps acting up i'm having issues diagnosing what is the problem
If just driving around it seemed to be ok all winter but if i ran the finish mower it was more prevalent of a problem this spring
Maybe somebody has some advice
/ FRONT WHEELS LOCKING UP #13
Update
Swapped the directional valves on the hydrostat (didn't replace just moved one from one side to the other???) replaced all the solenoids and the machine is back going again (replaced with aftermarket solenoids for a fraction of the price
part #6682953
Throwing a rear wheel sensor code 50-14 i have a spare so that will be replaced next
207277 (A52708)
207277 (A52708)
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
17501-FL (A56857)
17501-FL (A56857)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
