front mount snowblower
/ front mount snowblower #1
frankie14001
akron,n.y
kubota L3130
I have a cat 257b2 track skid steer it puts out 15.6 gpm.I have a 3 pt hitch 60 inch snow blower would like to front mount it to the cat. Would it be possible to buy a hydro motor that would work off the cat to have enough rpms and torque to work snow blower if there is what type of motor would I need thanks
/ front mount snowblower #2
I believe Bob Cat makes one that will work on your Cat with no mods. Ed
/ front mount snowblower #3
You really need high flow hydraulics on a skidsteer snowblower. Between the hydraulic system losses, separate fan and auger motors, the snowblower performance will be disappointing with standard flow.
30-40 gpm at 3500-4000 psi is needed with 80-100 hp engine.
/ front mount snowblower #4
Take a look at Loftness blowers. I have the 601 which is 60"wide and needs 15gpm. I'll get the motor model and send it along. I put a pto power pack for 20gpm because my L39 auxiliary hydraulic maxed out at 11gpm. It worked, but won't throw some snow far enough.
Rob
/ front mount snowblower #5
My unit (601e)has a Char-Lyn c104-1061. That's a 4.9 GPM motor. Surplus center has it for about $520. Their 17-20GPM unit( EM) uses charlyn c104-1062 . ( 6.2 cu in)
/ front mount snowblower #6
The 6.2 cu in motor would be the better choice for running at 540 RPM with 15.6 GPM.
I would estimate that you will get the equivalent torque as 20 - 25 PTO HP
2022 EZ-GO ELITE...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2023 CASE TV450B SKID STEER (A64279)
2023 CASE TV450B...
John Deere 4300 32HP Loader Utility Tractor (A61572)
John Deere 4300...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
3268 (A63117)
3268 (A63117)
