front mount snowblower
/ front mount snowblower #1
frankie14001
akron,n.y
kubota L3130
I have a cat 257b2 track skid steer it puts out 15.6 gpm.I have a 3 pt hitch 60 inch snow blower would like to front mount it to the cat. Would it be possible to buy a hydro motor that would work off the cat to have enough rpms and torque to work snow blower if there is what type of motor would I need thanks
/ front mount snowblower #2
I believe Bob Cat makes one that will work on your Cat with no mods. Ed
/ front mount snowblower #3
You really need high flow hydraulics on a skidsteer snowblower. Between the hydraulic system losses, separate fan and auger motors, the snowblower performance will be disappointing with standard flow.
30-40 gpm at 3500-4000 psi is needed with 80-100 hp engine.
/ front mount snowblower #4
Take a look at Loftness blowers. I have the 601 which is 60"wide and needs 15gpm. I'll get the motor model and send it along. I put a pto power pack for 20gpm because my L39 auxiliary hydraulic maxed out at 11gpm. It worked, but won't throw some snow far enough.
Rob
/ front mount snowblower #5
My unit (601e)has a Char-Lyn c104-1061. That's a 4.9 GPM motor. Surplus center has it for about $520. Their 17-20GPM unit( EM) uses charlyn c104-1062 . ( 6.2 cu in)
/ front mount snowblower #6
The 6.2 cu in motor would be the better choice for running at 540 RPM with 15.6 GPM.
I would estimate that you will get the equivalent torque as 20 - 25 PTO HP
iDrive TDS-2010H...
213086 (A64276)
213086 (A64276)
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
ARIZONA DRIP SYSTEMS-SUNDANCE TAPE INJECTOR (A64280)
ARIZONA DRIP...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2025 Kubota L4060D 42HP 4WD Utility Loader Tractor (A61572)
2025 Kubota L4060D...
