Snow Attachments Front Loader - ok for plowing snow?
/ Front Loader - ok for plowing snow? #1
NoviceguyInCT
CT, Litchfield County
BX24 TLB & old JD 400, JD H140
Looking at purchasing MF 2310 TLB or BX24 TLB.
I have a 200ft tar driveway, can i use a FL to plow snow? I know it won't be as good a blade or snow thrower but the dealers want big bucks for a blade or snow thrower.
Jim
/ Front Loader - ok for plowing snow? #2
I have a Legacy XL that I bought last summer. Use the FEL to plow snow on a 100' blacktop drive. One of the things I've learned is the angle of the bucket makes a big difference. I can see tearing up a stone driveway with a FEL but honestly think a blade would too if not set correctly. I say go for it.
/ Front Loader - ok for plowing snow? #3
You can do it for your short drive and, as you already realize, it isn't going to be as good as some alternatives. Just that you will get more tractor time with the FEL. /forums/images/graemlins/wink.gif
Enjoy the snow while it lasts.
/ Front Loader - ok for plowing snow? #4
Yep - sure can. I just plowed my drive with about 5" on it and it worked great. I have gravel so I put it in the float position and just drive forward. It sometimes misses a bit where there are low spots but it works great compaired to spending a ton of $$ on a blade or thrower. Unless you have to plow everyday all winter I would just stick with the FEL personally. Good luck
/ Front Loader - ok for plowing snow? #5
Don /forums/images/graemlins/cool.gif
/ Front Loader - ok for plowing snow? #8
Novice,
Buy a BACK blade. Put it on the 3pt and you will be done in 1/10th the time. Being able to angle the blade and slide the snow off to the side makes all the difference.
Oh, you have to go backwards...
Used blades are in the 100-200 range. Go to some farm auctions.
/ Front Loader - ok for plowing snow? #10
I did mine all last winter with my FEL. After using the FEL, my Gravely with its 4' snow blade went into disuse. The FEL is particularly useful around the garage and parking area.
Bought a back blade for this year but have only used it twice. In small snowfalls, driving forward works fine. I actually haven't used it going backwards.
Ralph
/ Front Loader - ok for plowing snow? #11
</font><font color="blue" class="small">( Buy a BACK blade.
)</font>
WHEW! Sounds like a recipe for a SERIOUS stiff neck - my drive is 1.5 miles long! /forums/images/graemlins/frown.gif
/ Front Loader - ok for plowing snow? #12
I've been using my FEL for six years to plow our driveway. My plow is sitting in the shed, I never put it on anymore. I have a 6 ft bucket that I put in the float position and it hasn't hurt the blacktop. I like the ability that the FEL gives you to scoop the snow up and pile it high.
Cub Cadet LTX 1042 Riding Mower (A66408)
Cub Cadet LTX 1042...
Skid Steer Roto Tiller (A65640)
Skid Steer Roto...
2007 KENWORTH T800 TRI/A ROLLOFF TRUCK (A59914)
2007 KENWORTH T800...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
Trailking Detach Semi Trailer (A66285)
Trailking Detach...
