Front loader brush cutter
/ Front loader brush cutter
That's quite a mower. What type of mowing do you want to do? After having experiance with mine, I just am aware of some of the drawbacks, or limitations with this type of mower. Travel (mowing) speed being just as big a question as your limited hydraulics available on your tractor IMHO. FWIW I have modified my 8' rear 3pt. mower for the tractor so that I can lift it about 4' (some of that with a hyd top link) and it is hard to beat a driveshaft to get your HP to the mower, and favor this set up over the hyd. driven loader mount mower on my 115hp skid steer.
I am mowing dense undergrowth that is hard to get with the bush hog, I would rather have the mower infront so the trees don't damage the undercarriage of the tractor to much. Here's some pics of the growth.image.jpgimage.jpg
/ Front loader brush cutter #32
The case drain would just connect back to the tank/reservoir. I am cautious of QD's on case drains
Do tractors typically have a case drain plumbed in ? I'm very familiar with construction equipment and we use QD's all the time with the only problems being when guys don't connect them
/ Front loader brush cutter #33
No, tractors don't normally see case drain hoses.
They could be teed in with return lines if there is no back pressure.
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Advanced EV Cart NR (A59231)
Advanced EV Cart...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
208735 (A60430)
208735 (A60430)
iDrive TDS-2010H...
2020 CZ Engineering CZ15KP 26ft Pole Trailer (A59230)
2020 CZ...
