Front end snowblower
/ Front end snowblower #1
Orebonder
Branson / 5220c
Converted rear mount PTO driven to front mount hydraulic driven
More pictures
And a few more pictures
In the past I would run the tractor at 2000 rpm ( PTO driven) to get the snowblower really throwing snow.
This is the tach study I did using the hydraulic motor
I have a 16 tooth on hyd motor and 15 tooth on ( snowblower) gearbox..notice the 2000 rpm .... right on the money!
/ Front end snowblower #6
That is an awesome thing that you did. I really appreciate the pictures of the steps that you have shown. Did you just complete it or have you tried blowing with it? I would love to try this myself, plus awesome idea for a hydraulic reservoir.
/ Front end snowblower #7
If I had 25% of your talent, I would attempt it. IMO the best snow set up is SSQA blower and a rear blade...at least for my needs where I live in northern MI. I doubt that would be possible with your design as the oil reservoir would need to be reloacated/changed.
I had to go with a compromise. SSQA mounted blade and a pull blower.
I admire your work.
Thanks...I just completed it the build. I use the Tractors’ onboard hydraulics for the two way chute operation. I used Discount Hydraulic Hose ( online) for most of my hoses.
suggestion ...order all your hoses at one time from them...makes shipping very cheap. I paid way to much ( almost 4X) for my first two hoses at a local Hydraulic service store ( learn as you go).
Making my hydraulic tank saved a tons...($200.00 , fittings included) plus I like the rounded look... I saw some square tanks listed Online at $4000.00!
I ran the unit for over an hour at 2000rpms ( which is where I usually run it for real heavy snow) on a 65 degree day...temp went up to just over 100 degrees.....at that’s with only 15 Gallons of oil in the 20 gallon tank ( just wanted to see what it would do with 15 gallons).... I was very pleased!
Looking forward to lots of snow next year..!
I admire your work.
I can switch back and forth pretty quickly...easily..
I built this snow blade a few years back
Thanks
2011 AMERICAN 14 T/A DOG HOUSE (A65643)
2011 AMERICAN 14...
New/Unused AGT Industrial LRT23 Mini Skid Steer (A65583)
New/Unused AGT...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
