Front end snowblower
/ Front end snowblower #1
Orebonder
Branson / 5220c
Converted rear mount PTO driven to front mount hydraulic driven
More pictures
And a few more pictures
In the past I would run the tractor at 2000 rpm ( PTO driven) to get the snowblower really throwing snow.
This is the tach study I did using the hydraulic motor
I have a 16 tooth on hyd motor and 15 tooth on ( snowblower) gearbox..notice the 2000 rpm .... right on the money!
/ Front end snowblower #6
That is an awesome thing that you did. I really appreciate the pictures of the steps that you have shown. Did you just complete it or have you tried blowing with it? I would love to try this myself, plus awesome idea for a hydraulic reservoir.
/ Front end snowblower #7
If I had 25% of your talent, I would attempt it. IMO the best snow set up is SSQA blower and a rear blade...at least for my needs where I live in northern MI. I doubt that would be possible with your design as the oil reservoir would need to be reloacated/changed.
I had to go with a compromise. SSQA mounted blade and a pull blower.
I admire your work.
Thanks...I just completed it the build. I use the Tractors’ onboard hydraulics for the two way chute operation. I used Discount Hydraulic Hose ( online) for most of my hoses.
suggestion ...order all your hoses at one time from them...makes shipping very cheap. I paid way to much ( almost 4X) for my first two hoses at a local Hydraulic service store ( learn as you go).
Making my hydraulic tank saved a tons...($200.00 , fittings included) plus I like the rounded look... I saw some square tanks listed Online at $4000.00!
I ran the unit for over an hour at 2000rpms ( which is where I usually run it for real heavy snow) on a 65 degree day...temp went up to just over 100 degrees.....at that’s with only 15 Gallons of oil in the 20 gallon tank ( just wanted to see what it would do with 15 gallons).... I was very pleased!
Looking forward to lots of snow next year..!
I admire your work.
I can switch back and forth pretty quickly...easily..
I built this snow blade a few years back
Thanks
Saddle Tanks (A65640)
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
