Front End Loader For F15D
/ Front End Loader For F15D #1
F15DOWNER
Rome, Ohio
Yanmar / F15D
Do any of you know if I can get an FEL for an F15D?
So far I haven't heard anyone talking too much about the F series tractors. Are they just too new in the US and the market isn't there yet?
I know an F15 is a little light but, with a little weight in the back it should do OK.
How about it Len, Aaron, Dave any insight?
I attached a picture of the beast.
Tom
/ Front End Loader For F15D #2
I had to dig through my pictures to be sure but we put a Koyker on an "FX" series. I can't remember what model it was but I attached a picture of it. I am alnost sure they are avail for the F15.
/ Front End Loader For F15D #3
Hoye tractor put an "armadillo" loader on my FX28D. Seems to be well built (metal lines, 2 pistons), but I am no expert.
/ Front End Loader For F15D #4
That is another option. You could always get a "homemade" loader put on it. We could put one on it like the one on cfoxmd's FX28. Depending on where you live.
/ Front End Loader For F15D #5
I have a Koyker on my FX26D. See the attached picture.
/ Front End Loader For F15D #6
And another picture.....
/ Front End Loader For F15D #7
Brent
Is the fx26 the same size as an fx24 body wise?
hood ,width, ect..
Ern. <><
Thanks Guy's
I ordered a Koyker catalog online.
Tom
/ Front End Loader For F15D #9
There is a guy selling a new Allied loader on eBay. Check out Item # 2071714533 , it might fit your tractor.
/ Front End Loader For F15D #10
There was an FX24D that came on the same container with the FX26D and the 24 was a bit smaller.
/ Front End Loader For F15D #11
Koyker has a mount kit for a 110 for a F16. I've never had a F15, but I do know that the F155 is entirely different than a F16, but as a newer model that is no surprise. The F18 is entirely different than the F16...so we really can't be sure without some measuring.
Koyker would probably fax you (or their local dealer) the mount dimensions and you can compare them to the F15. Often you can get a very close mount and just modify it slightly to fit. Only do this if you have the capability to do it right.
I a manufacturing Engineer in a machine shop, so this is right up my alley.
Thanks
Tom
/ Front End Loader For F15D #13
Tom, sounds like you are certainly qualified. Koyker also makes a universal mount kit, that basically comes with the correct pieces you need, but requires cutting and welding. It is a good place to start if they do not have the correct or similar mount that you need. Just remember to check the tire clearance throughout the range of motion of the steering and the pivot of the front axle. Bummer to forget the pivot part and have to take the plasma cutter to newly fabricated mounts! ...not that I have ever had to do that......
2018 International WorkStar 7500 T/A Matador 4,500 Gallon Septic Wet Vacuum Truck (A61573)
2018 International...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2021 John Deere 50G Mini Excavator (A62613)
2021 John Deere...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
