Front End Loader & Box Blade on L3130
   / Front End Loader & Box Blade on L3130 #1
icat
Katy, Texas
Kubota L3130 HST
I have narrowed my tractor seach down to the L3130 HST. Now comes "add on" time. I need/want/gotta have an FEL, but which one. The LA723 is $500 more than the LA513. With the LA513 and the other extras (R4, Box Blade, and Rotary Cutter) we're pushing $20k as is. I can not find a photo of a LA513, nor is there one in town to look at. I'm concerned that there are "disadvantages" other than size of the bucket and lift height. Can anyone with an LA513 tell me if they wish they had opted for the LA723? Are the hydraulics, arms, etc. beefier (is that a word) on the larger FEL? Or is the majority of the cost savings in the bucket alone? Usage of the FEL will primarily be landscaping & manure moving on 18 acres. The dealer told me that the LA513 would be his choice. Then he told me he doesn't have the LA723 in stock. So I'm abit concerned that the situation would be reversed if he only had the LA723 in stock.
Second question - box blade. I've read that I'll need to have a 6' box blade to "cover" the tracts of the R4's. Can someone confirm? I had originally requested quotes on a 5' Box Blade, but it now appears that may not be the best choice. Also, does anyone have the Kubota Box Blade. The dealer (who doesn't stock the blade) advises me that the Kubota blades are VERY expensive. Is it just the name, or is it a high quality unit?
Gotta thank each and everyone of you for the help so far. I am very glad that I found this site - it has been a world of help.
   / Front End Loader & Box Blade on L3130 #2
The 723 has about 40% more lift capacity than the 513. See Kubota's side by side comparison for precise specifications. I think the Kubota model numbers indicate the lift capacity in kilograms at bucket center.
Also, look at TractorSmart, under New Equipment/Kubota/L Series/Loaders, for all the options available for each loader, as well as "factory list" pricing.
Kubota recommends either a 65" or 72" box scraper for this tractor. I don't have any experience with the Kubota units, just have noticed how heavy-duty they appear to be.
   / Front End Loader & Box Blade on L3130 #3
The 723 loader will lift about 400 lbs more than the 513; not that the 513 numbers are low. The bucket is 6" wider.
If you want the skid steer type quick hitch in order to mount pallet forks or bale spears, you probably also want the extra capacity of the 723. For example, the 723 500mm forward lift capacity is 1400 lbs. With a bale spear, you probably still would be limited moving hay bales. With the 513 capacity of 1003 for 500mm forward, probably could rule out hay. For typical uses, the 513 probably has plenty of heft. If you are like me, it seems to make more sense to spend the extra few buck for the capacity since already spending so much on the FEL.
The price for a 6' box blade vs 5' should only be a few dollars for same quality units.
Terry
   / Front End Loader & Box Blade on L3130 #4
I have had my L3430 for a week now, its the same size as the 3130. I have 723 loader 72" 4-n-1 bucket, 6 ft box blade and r4 tires. You will need 6ft. blade to reach the outsides of the rear tires, same for bucket. I believe there are 4 width settngs for rear tires. At widest settings, I believe the outside of rear r4's would actually be wider than 72". I have mine set at 3rd setting, I think just less than 72". Will measure tonight and post if you want.
The round hay bales were a concern, but the dealer indicated that I really couldn't move the big bales with either loader. He suggested other ways to move the bales and I tend to agree with him.
I'll ask for a new quote using the 6' box blade - looks like that's a must for covering the tire tracks. Any recommendations on brand?
Still interested in hearing from someone who opted for the smaller FEL.
Thanks for the replies!
   / Front End Loader & Box Blade on L3130 #6
3050 (Daryl?) has several posts where he talks about the ability of the 853 loader to handle round bales with ease. cowboydoc has also demonstrated that his JD will handle round bales that weigh a lot more than the rated capacity of the loader.
I wouldn't give up so easily on the idea of the 723 handling round bales.
Good point. I think the dealer will understate the abilities of the tractors (and loaders) to handle certain situations to protect themselves from liability issues. I'm pretty sure the L3130 would NOT be a good tractor if all I did every day was load 1800 lb. round bailes on trucks for delivery. On the other hand, for moving the occassional round bail 100 yards or so the tractor and loader would most likely be ok. In which case I think the LA723 would be the better loader.
   / Front End Loader & Box Blade on L3130 #8
Checked my setup tonight, as is L3430 with r4's, tread width at rear is about 68 inches (outside of tread left to right), total outside of tire to outside of tire is 71+ inches. This can be increased an additional two inches on each side or reduced an inch or so each side. Hope this helps.
Thanks, that pretty much confirms that I'll need the 6 Foot Box Blade.
Got new quotes today! The margin is widening. Spoke to a dealer today and he gave me a great price, but he isn't any where near the property so service would be an issue. He also indicated <font color="red"> NOT </font> to go with the LA723 on the L3130. He says he doesn't feel the tractor can handle the extra weight when the bucket is full. He also insisted that the L3130 will pull a 6 foot cutter! /forums/images/graemlins/shocked.gif Any one pulling a 6' Bush Hog with this setup?
   / Front End Loader & Box Blade on L3130 #10
It seems to me that if Kubotas engineers that designed theL3130 say that It can handle the La723 it very well should. After all they work for the company that pays for the warranty. Just a thought. /forums/images/graemlins/smile.gif
Don't get me wrong - I totally agree. That's one of the reasons I was a bit uncomfortable with this dealer.
   / Front End Loader & Box Blade on L3130 #12
The L3130HST, L3430HST and L3830HST weigh 3305, 3305 and 3340 lbs, respectively. Each one of them has the same hydraulics. Where in the world would a dealer get the idea that the L3130 wouldn't handle the 723 Loader?
I think someone is blowin smoke up your skirt. /forums/images/graemlins/blush.gif It sounds like both dealers have a 3130 with the 513 loader ready to roll out the door.
   / Front End Loader & Box Blade on L3130 #13
With 3430 - I used the 723 loader all last weekend taking apart a deck, rather heavy, wet pressure treated lumber in large sections. I used box blade for balast, additionally, I think the 4n1 bucket with tooth bar is likely more weight than standard bucket? - No problems, front end never felt "too heavy", my tires are filled so I can't confirm use without filled tires and a rear balast. Basically, anything that I could pick up, I could move to my pile without problems.
Yeah, I think they're pushing what they have in stock as well. At any rate, I just don't feel comfortable with the dealer so they're out of consideration.
After reviewing my notes (and putting all the pricing into an Excel spreadsheet) I've come to realize that the dealer who is very close to the property has the best deal anyway. I e-mailed him about upgrading to a 6' box blade and the LA723 loader and he only added $400 to the package! Now that's a slam dunk. So, it looks like we have a winner. Going out on Saturday to "meet the dealer" and check out his shop. He doesn't have the loader (either one) in stock, so I know he's not trying to get rid of stock. Once I confirm everything I'll let you guys know the details! /forums/images/graemlins/grin.gif
   / Front End Loader & Box Blade on L3130 #15
Keith, you going with Rioux?
Funny I asked Lansdowne about the 302 (bigger) loader on the 7500 and they said all they put on was the 272 (smaller), again possibly pushing what they have in stock?
   / Front End Loader & Box Blade on L3130 #16
icat,
Just for comparison purposes, Deen Implement (an advertiser here on TBN) outside of Dallas is running a special on a package deal similar to yours for $19,205. Look for the "Monthly Specials" link on their website.
• L3130HST
• Kubota LA723 - w/Skid Steer Quick Attach
• Bush Hog SQ720 - 6' Rotary Cutter
• Bush Hog SBX720 - 6' Box Blade
If the shop is as clean as I expect it to be, then Rioux it is! Quote came out to $18,955 for the package. Price includes the L3130 HST 4WD with R4 tires, LA723 FEL, 5' Bush Hog SQ600, 6' AMI Box Blade, and delivery. This is just over $1000 less than I was originally quoted at Roach.
I will need to wait a bit as he doesn't have everything in stock, but that's not really a problem. He indicated that it will only take a week to round it all up. /forums/images/graemlins/smile.gif
Bill,
Thanks for the info. I had looked at Dean early on but the distance is just to far to make me comfortable. Luckily Rioux will be able to better their price AND deliver.
Woops - didn't see the larger cutter and QA. But delivery would still have been an issue.
   / Front End Loader & Box Blade on L3130 #19
icat,
It sounds like you've got a real good price, especially with R4's. Deen's deal is with R1's. Deen told me that the 3130 would handle a 6' rotary cutter just fine. Rule of thumb is same size box blade and rotary cutter, and don't forget that your tractor's footprint is 6' wide.
Also, that SS/QA option is supposed to be real handy. It's probably an extra $300 or so, but gives you flexibility to use pallet forks and a bale spear. /forums/images/graemlins/cool.gif
Like I said in another thread, this package is the one I want, if I could only justify it. Right now, I only get to see my tractor about once a month, but he's old and doesn't mind. /forums/images/graemlins/wink.gif
   / Front End Loader & Box Blade on L3130 #20
icat,
One other thing to consider. If you don't need to bundle the implements with the tractor for the 0% financing, you might look for some Midwest implements. I think you could save enough on a box blade and rotary cutter to pay for the QA, and end up with heavier, and perhaps superior, implements.
I know that Midwest is selling its line in Kioti Orange through Kioti dealers. Maybe there's one near you. Check at Kioti's web page for implements and dealers.
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
