Tractor Sizing Four (4) Considerations in Tractor Selection
/ Four (4) Considerations in Tractor Selection #21
What it should come down to is which brand has the best dealer. Would i have bought a Deere or Massey, he’ll yes if i didn’t have to waste a day to go to a decent dealer for parts or service. I bought a kubota because I have 5 great places within an hour and a half drive. If I bought a Deere it would be 2.5 hours one way and if I bought a Massey it would be 2 hours each way. I could have bought a new Holland but would have to go over 4 hours to find a good dealer. Kioti is out of the question for me I had one and sold it because I couldn’t buy parts in stock within a days drive each way they really need to improve there dealer network if they want to be a contender
/ Four (4) Considerations in Tractor Selection #22
I somehow knew from my own and engineering knowhow that 18 hp was enough for me. Looked at JD (who had one then) and Kubota offerings. Nothing else in our area at that time. Think one of the present Kubota dealers had Yanmar. JD was, by far, the closest dealership.
Still wish I could get another 18.5 hp JD with turning brakes like the 4010. Nope. Next tractor at this time will be a Kubota B2300. The BXs have that cooling fan down below, to get down to 18 hp. Next the extra clearance of the B or 2 series JD.
Ground clearance and minimum 18 hp and reasonably close dealership were my main criteria. Want turning brakes, too.
/ Four (4) Considerations in Tractor Selection #23
My opinion is most people buy off of specs without demoing/testing the machine they want "in the setting they will use it in"...
/ Four (4) Considerations in Tractor Selection #24
It is really not an "either"/"or" situation. You read reviews, go around to the dealers, ask a lot of questions and drive a few that meet the specs you want. Work out the pricing for how you want it set up. Go to the next dealer and do the same. At some point you have to make a decision. Impressions and general feel of both the dealer and tractor are important but you still have to go over the numbers... price, HP, PTO HP, weight (both gross and loaded) and lift capacity, whatever else is important.
/ Four (4) Considerations in Tractor Selection #25
If specs and a test drive around the lot is all you need that's cool but I need more. If they won't let me demo it in a real life situation I won't buy it.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
Background of above tenets:
/ Four (4) Considerations in Tractor Selection #27
Thanks for the link! I do agree with this common sense approach and methodology, I was just pointing out that I don't use "bare weight" as my first criteria. I typically use HP first and then verify that the TOTAL weight of the package supports the application. Either methodology will likely result in the same tractor selection.
For example, if looking for a tractor to pull a small square baler, the implement requirement might specify that you need 62 HP. It also mentions that the tractor should weigh at least as much as the baler. It's much easier to initially identify options based on the HP spec than on the weight spec.
I especially agree with the statement that "Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance." This is obviously a very personal issue because many members have posted that having a good local dealer is critical to them. For me, it's way down on the list. I usually buy used so not getting warranty service. I'm as likely to order my parts online as I am to go to a dealer -- and get them just as fast. I'll pretty much tackle any repair. I've also found that my local farm equipment dealers are willing to work on pretty much anything. I admit that I don't follow the maintenance manuals 100%. I focus on the wear points and lube points and probably miss some adjustment checks, but when something breaks, I'm inclined to tackle it myself.
Overall, I think we ultimately use the same approach. But I think that it might be more accurate to say that we consider the whole package (application, weight, HP, cost, features, . . . ) simultaneously as opposed to ticking off specific criteria one-at-a-time. It's hard for me to be that one-dimensional in my thinking when I'm looking at a tractor.
Thanks again for the link and history.
/ Four (4) Considerations in Tractor Selection #28
MossRoad - June 2021:
There's a balance between bare weight, additional weight, weight distribution, traction, flotation, soil conditions, etc.
Too much emphasis on bare weight, in my opinion.
OK:
The most important consideration is "what are you going to be doing with the tractor?" Once you figure out what you are going to do with it and how fast and often you want to do those jobs, that will tell you what implements you are going to run, and that will give you the tractor size, weight, power, and hydraulic capacity you need, sometimes with some wiggle room. For the wiggle room, if you are more worried about getting into smaller spaces, pick one at the smaller end and if you are more worried about speed/capacity, pick one at the bigger end. As long as you accurately identify what you are trying to do and don't get into the situation where your tractor is clearly too large or small for the implement/job you need to run/do and it cannot do that job/run that implement, there is plenty of wiggle room and a few percent different in size, weight, etc. isn't going to really matter.
Generally the decisions the buyer has to make once they have decided what jobs the tractor is going to do are personal preference decisions- brand/exact model chosen, specific transmission chosen, open station vs. cab, MFWD vs. 2WD. Driving one can help here as spending some seat time can help you to see which one fits your preferences the best.
/ Four (4) Considerations in Tractor Selection #29
After going through all this same spreadsheet analysis when buying my tractor, the biggest thing I learned was it's mostly a waste of time. More size and weight are not always better, nor is cheaper. An extra 100 lbs on the FEL is great but is it really going to impact your day-to-day? Not likely. Two vs three range tranny? Linked pedal? FEL goes 6 inches higher? Plastic versus metal? DPF? Meh, outside of a few very specific scenarios it's all good. Even an extra $1000, who cares. Yeah that's a lot of money but over 10-20 years it's meaningless. It's like buying a house where you agonize over all these little things that 3 months after moving in you don't even notice or care about any more.
Personally I'd say just be knowledgeable about what you'll really be doing with it and then go with your feel - you'll know what feels right and makes you happy and that's 90% of it. Every manufacturer makes a tractor that will be excellent for you and your land, so agonizing over the minutia is fine if that's how you want to spend your time, but for me I'd focus on the real difference makers like access to a broad, reliable dealer network and wide availability of parts and information. I'm a DIY'er so I want to be able to find my own solutions and learn from others with the same tractor, and I want my parts within 48 hours at the latest, preferably without having to leave the house. There's nothing worse than searching online and feeling like you're the first person on planet Earth who's had some problem, or having to rely on your dealer to order some part from Estonia that'll take weeks to get. But even as a DIY'er, there will always be those issues where you absolutely need a good dealer and it's then that it becomes invaluable.
/ Four (4) Considerations in Tractor Selection #30
Mostly agree. The two things that instantly stand out to me in your list though: Yes, an extra 100 lbs on the FEL can absolutely be noticed if that is the exact amount of extra weight you need to lift, and your FEL can't do it. And two, the 2-range vs 3-range trans is a huge deal. A two range machine is too slow in L and too weak in H, medium is the goldilocks range for the vast majority of FEL work on a larger machine.
/ Four (4) Considerations in Tractor Selection #31
The devil in the details... one of the reasons the spreadsheet was useful to me was that there were 3-4 tractors that i really liked, all pretty much did what I need to do based on "feel" and other factors like reputation and distance to dealer, brand reviews, etc. It started out with me looking to replace my aging MF1250, so I was initially looking at the 1740M. As I drove it on the lot I was reminded of the times that the 1250 just didn't have enough weight or power to do certain tasks, so I started looking at the 1840M, bigger but same HP. Then it occurred to me that I had been pulling a 60" rotary with the 1250 pretty well but the 1840 seemed sized better for at least a 72" cutter but maybe wouldn't be enough PTO HP to do it well. I went from a "impulse buy" of an exact replacement to a search for what the best replacement might be. I did a lot of browsing on the internet and visits to dealers to decide what my needs were for a new tractor. I have a lot of experience with Excel and was able to very quickly throw together a spreadsheet from the stack of brochures that I had. Viewing the specs and costs side by side made it easier for me to make the "final cut" from several very similar machines. I never meant it to mean that this was the best or only way to choose a tractor. Only that it can be a useful tool to help narrow down the choices.
Looking to buy my first Kioti tractor for my 26 acre farm. The tasks are bush-hogging 20 acres once per year that includes steep hills, tilling my vegetable garden, 1000 foot gravel driveway maintenance, cutting and hauling wood for winter and just general tractor and loader work.
I think the ck2610 would suit most of my needs except bush hogging.
Subcompact and compact tractors under 3,000 pounds bare weight operate in landscape, kitchen/commercial garden or hobby farm applications on one to ten flat acres.
~~ BUY ENOUGH TRACTOR ~~
Bare tractor weight first
Looking to buy my first tractor for my 26 acre farm that includes steep hills.
CK2610 is too light/narrow/unstable for your topography and tractor applications.
Every tractor producer has at least an economy and deluxe model in the 4,000 pound bare weight category, with a 66" width and 40 to 60 horsepower. These are the mid-weights in the compact tractor category and sell in high unit volumes.
I am assuming I can run a 6ft BH and might get away with a 7ft.
Mowing once per year you will need a heavy duty Rotary Cutter weighing 1,100 to 1,500 pounds and at least 50 engine horsepower to spin it cutting 5' to 7' tall grass and a year's production of brush.
If contemplating a cab tractor, 60 engine horsepower would be better. The cab weighs ~ 700 pounds ~ and the air conditioning requires several horsepower.
Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. A 6" to 10" increase in rear axle width substantially decreases tractor rollover potential. Tractor width is an approximation of rear axle width.
Small tractor wheels drop into holes, disrupting traction. Larger wheels and tires supplied on heavier tractors bridge holes and ruts, increasing traction. Larger wheels and tires permit higher operating speed over uneven ground by reducing implement bounce and operator perturbation.
To apply 60-horsepower to the ground with an open station tractor you will probably want rear tires filled 50% or 75% with liquid to lower tractor center-of-gravity and bolt-on wheel weights.
If you are considering a cab tractor the cab weight substitutes for wheel weights.
Tasks include hauling wood for winter and just general tractor and loader work.
With this ballast on the rear wheels you will be able to lift 65% (+/-) of Loader capacity without a Three Point Hitch implement mounted.
/ Four (4) Considerations in Tractor Selection #33
The name of this sub is Buying/Pricing/Comparisons. It is primarily for people shopping for a new tractor and is one of the first places I came to when I was looking to buy earlier this year. The information here helped me to rethink my initial choice to replace my old tractor. Originally I was going to basically just buy a newer version of the same tractor. With the information I got here I wound up buying a much heavier tractor with a moderate increase in size and HP.
I am amazed at how many people post on here asking advice on what to buy, but seem to have already decided on a ~25HP sub or some other small CUT. You then read the same advice over several pages and dozens of posts that you've already read in similar threads, and it seems most of the time they go ahead and buy that tractor that is likely too small to do what they said they wanted to use it for. Occasionally you actually see someone take good advice to heart and buy the "right" tractor.
For a novice tractor buyer, the advice that Jeff has compiled from previous posts by members and from other sources is often the best single post that they will come across to give them the basic information for choosing what is best for them. Not sure why so many on this forum deride Jeff for regularly bringing this information to the top, but to me that is what the purpose of this sub is for. This "List of Criteria" is not just "Jeff's opinion". It is a compilation of over 14,000 posts on this sub. A new buyer can read through 13 pages of 87 posts on any single thread and eventually come to the same conclusion that first thing you need to determine is what you will be using the tractor for, then use these requirements to decide which tractor is best for you. Once you get past the basic minimum requirements, then you are in a better position to decide what specific brand and model. That is potentially where the the best discussions come in. In any case, one of the first things a novice tractor buyer should see on this sub is that list of criteria as a starting point.
/ Four (4) Considerations in Tractor Selection #34
There isn’t a Kioti dealer within 100 miles of here, but 4 Kubota dealers. 2 are 20 minutes drive each direction , so I just bought what everyone around here uses
/ Four (4) Considerations in Tractor Selection #35
SPREADSHEETS. I was just reading through these posts and a few things stood out.
One was the homemade spreadsheet for comparing different tractors. That's real nice especially for someone just getting started and not yet used to comparing tractors. And fun for everyone else to read. I am more struck by the similarities in all the tractors than by the differences in different models.
WEIGHT. You have to own a tractor to understand the importance of weight. There are sort of two kinds of weight....one is a function of how heavily built that the tractor is. Big frame, heavy engine & transmission castings, solid wheels, heavy 3pt arms, big FEL parts...things like that. You can't add that stuff and it is golden.
The other type is additional weight & can always be added with wheel weights, ballast, and tire fluid - and that's better than nothing, but sure not as good as the other type.
A LOCAL DEALER....well, I don't know. YMMV. We just turned over 1000 hours in 15 years of ownership and I've been to the dealer twice - both times just because I was out that way so stopped in to buy special lubes. The tractor hasn't needed repairs - and I think that is typical and not at all unusual. That type of reliability is exactly why I bought a top of the line model. Yes, it has needed some parts like maintenance items, cables, hoses, gaskets, valves.... those I ordered online (Messicks) which is exactly what the dealer would have done.
Dealer avoidance only works for me because I have mechanical knowlege plus tools and like to use them both. If that isn't you, please take some advice from my years of having a repair shop:
Look for a dealer that has the best repair facility (ask to see it), and especially check that they have a mobile service truck and offer tractor pickup and delivery. If they don't have those things, they simply are not serious about service. If they don't have mobile service, and having dealer service is that important to you, definitely find another dealer - even if it means a different brand.
FEL LIFT. About the same across the board but often measured differently.
What does make a difference is not often mentioned: Visibility and quality of parts and hydraulics. Especially the influence of geometry and the quality of the hydraulic valves. Here's a test. Working against a load, can you move the FEL valve lever just a slightest bit and reliably get a controllable tiny movement of the front edge of the bucket? Or does it jump and shudder? You may not think so now, but in use that ability to feather the valve is huge.
HORSEPOWER: Get enough so that you don't have to always run wide open to pull the load. You may choose to run high RPM for emissions, but at least you have the option.
GEARS & RANGES: More is better. Always.
3PT Hitch: You want hand crank adjusters and telescoping arms.
ROPS: Get an insulated factory canopy to fit that ROPS.
EXTRA HYDRAULICS: Get at least one. Either front or back. You can then add more valves & long hoses as long as you have one extra outlet somewhere.
SEATING: However you do it, upgrade the seat. Your back will benefit.
EAR PROTECTION: I bought several headsets, and found that so far my $30 basic Swiss shooter's headset works better in most ways than the Bose, JD, and Sony noise-cancelling headsets that cost 10x as much. It's not as comfortable though.
TOOLBOX & LUNCHBOX: You have to make your own.
Good Luck in your tractor search,
rScotty
TYM T494
The TYM T494 is 3,900 pounds bare weight with 48-horsepower gross. A good balance of weight and power. Chassis is 63" wide, which makes it a stable platform on moderate slopes. With 63" chassis width, probably ~ 69" ~ tire width, you will use at least 72" operating width implements. With 48-horsepower you can power a 72" Rotary Cutter through high grass and thick brush. This weight/power tractor is suitable for working five to twenty acres of crop land. Fuel use will average ~.6 to .7 gallons~ per hour.
This is the mid-weight in compact tractors, a high unit volume segment. Every tractor manufacturer offers at least two models in this approximate weight. Horsepower ranges from forty to sixty in tractors in this weight.
Before you order evaluate critically the staying power of your TYM dealer through a recession.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My Kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after nine years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
/ Four (4) Considerations in Tractor Selection #37
You guys are all talking about Ag tractors and their jobs.
For me, there are places a big tractor cannot go, and I know from experience that I only need 18-19 hp and about 1400 # bare tractor weight to get all the jobs I need done.
People tend to overbuy tractor and pickup size.
/ Four (4) Considerations in Tractor Selection #38
Every tractor and vehicle I've ever purchased was tested with seat time beforehand. There really is no other way, IMO.
/ Four (4) Considerations in Tractor Selection #39
Local dealer is a strange one. You can go from long established, good dealer, to a new dealer in the stroke in the stroke of a pen. You can also go from a good dealer to no dealer at all.
/ Four (4) Considerations in Tractor Selection #40
OK:
I consider those things and more. There are also things that a spread sheet won't tell you. That's why I don't use them.
2023 Deere 325G (A60462)
2023 Deere 325G...
JOHN DEERE 3120 TRACTOR (A64280)
JOHN DEERE 3120...
SOLD- Kubota MX5400 land mgmt package
SOLD- Kubota...
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
