Forward Exit Horizontal Exhaust??
   / Forward Exit Horizontal Exhaust?? #41
I am tractor shopping and the reason I asked is the owners manual for my new to me Alamo SHD96 Flail mower says one cannot have an under tractor exhaust that exits to the rear.
Some of the tractors I've looked at have underslung exhaust systems, but I think they could be reversed and run forward. However, I have not run a tractor with a horizontal forward exiting exhaust.y buddies 3000 series knots has a vertical exhaust the exits the side of the tractor (stock setup) I've spent enough time in that machine to say it's not a problem. I was leery the first time I jumped in it. I was pleasantly surprised.
   / Forward Exit Horizontal Exhaust?? #43
I think we're all overlooking the big advantage of vertical exhausts on smallish, no-cab tractors. It's a great hand warmer in the wintertime while removing snow. And adjustable, too. The more heat you like, the lower you grab it.
Now that's funny! More so because it's probably true. Thanks for the chuckle.
   / Forward Exit Horizontal Exhaust?? #44
Question as I only have a tractor with a vertical exhaust stack.
Do forward exiting horizontal exhaust system found on many cause the operator to breath in lots of exhaust fumes?
I remember years ago being on the steerage hoe behind a tractor with a rear facing horizontal exhaust, my answer is definitely forwards.
   / Forward Exit Horizontal Exhaust?? #45
His main ????? was, Does a forward horizontal exhaust system make the operator breath in more exhaust fumes than usual & most tractor owners that have a tractor with a forward horizontal exhaust do not have a problem with excessive fumes being breathed in. & on my 2018 M-F 1526 that has that type of exhaust i don't have a problem with excessive fumes. & the exhaust exits on the left side at mid point forward.
   / Forward Exit Horizontal Exhaust?? #46
I have a MF 135 diesel with the exhaust exiting downward under the left rear axle. We’ve been using it for almost 50 years with a rotary cutter and a flail a bit. Unsure of what the issue might be using a flail. Other than getting ‘gassed’ when hooking up an implement. I do prefer the front horizontal exit on my Kubota for that reason.
Must be wet where you live. Here, in dry powder like soil conditions, any tractor work will send billows of powder dust into the air, and settles on the windshield. You’re good for only 10 minutes, then have to get out a squeegee to clean the window. I’ve modified mine so it blows ahead and up, rather than down.... helps a lot and now buying fewer air filters too.
   / Forward Exit Horizontal Exhaust?? #47
My Kubota L3400 has the forward facing exhaust and I get hit with fumes quirte often. My L2850 has vertical exhaust and no problems. My 364 IH diesel has under slung exhaust and no problems. Guess it is just a matter of preference but if I had a choice I would take the vertical every time.
   / Forward Exit Horizontal Exhaust?? #48
It’s the only thing I don’t like on my Deere 110 TLB
   / Forward Exit Horizontal Exhaust?? #49
It's not a matter of common sense. You can't predict that the DPF will regen and what happens if you're bailing? Or you're in the middle of high brush mowing? Things can go south very quickly. That's why they put a button there to cancel the regen process, however some people can miss it due to lack of knowledge.
The DPF does get temps above 1200F, so you can imagine how hot the gases at the exhaust will be. Just for the kicks, my dad's SUV was regenning one time and I grabbed a dry leaf and held it 4" away from the exhaust tip. That thing lit on fire almost instantaneously.
Mahindra claims that their tractors don't have regens, I guess this was a nice marketing move as people that don't quite understand the various emissions systems fell for it. However, they use a DOC, which is technically always regenerating/burning once it gets to the proper temperature. That's why it's very important with this system, not to idle too much and run high RPM, so it doesn't plug the DOC. One system is not better than the other and vice versa.
I guess the regen jockeys should do what the Aussies are required to do: Have a fire extinguisher on board!
Seems to me that having common sense would allow onee to avoid situations like that during regens and to not miss the opportunity to delay them. At least, it would for me.
DPF, DEF, DOC or not, never having to worry about regens (unexpected, untimely or not) or the need to make sure the DEF tank isn't empty or any of that is a huge plus for me.
This whole discussion demonstrates why I wanted to avoid a regen engine.
Plugging up? Ha. I lose sleep every night, tossing and turning worrying about the catalytic converters on my cars, trucks and tractors plugging up.
It must be working, though, 'cause it's never happened. I'll try to keep that whole 'one system is not better than the other' notion in mind but it won't be easy since I never, ever think about it until someone brings it up.
   / Forward Exit Horizontal Exhaust?? #50
Hi, I have a 1630 New Holland that the exhaust exits on the left side of the engine through a hole in the hood panel, angled forward. It is about mid shin height sitting on the tractor and seems to blow the considerable smoke well clear. Amcdust
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
(2) 10000 LB DROP LEG TRAILER JACKS (A57192)
(2) 10000 LB DROP...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
