Forum Upgrade - Any Issues?
/ Forum Upgrade - Any Issues? #641
When making a post, words and phrases are getting randomly doubled and other times I can be typing and nothing is going up on the screen. I can quote a post and there are times that the words and phrases get multiplied in the quote also. Is this something that you know about? It sure makes it hard to write a post. When previewing the post, the doubled wording usually goes away in what would be the actual post, but still shows doubled up in the composing section.
Very confusing to say the least. :confused3:
i've seen that. been typing.. look up and no text.. then it all comes in one quick jump.. then pauses.
other windows seem unaffected.. so doubt it is the internet connection.. more seems like the software is not echoing the characters back as typed.
/ Forum Upgrade - Any Issues? #642
The problem is we can't have the reply button without quick reply. So you are either locked in to reply to quote, or using the reply to thread button at the bottom. Maybe we should custom program it?
If custom programming is what it takes, that's what I'd do. If everything is properly structured and assuming the original programmers didn't write spaghetti code, I wouldn't imagine it should be too difficult to enable the reply button while diabling "quick reply" with a few tweaks here and there.
FWIW the double post issue is tied to quick reply. :mad:
I suspect that people are getting tired of waiting on "quick reply" to finish (it's very slow) so they click again, resulting in a double post.
/ Forum Upgrade - Any Issues? #643
There are often ads downloading while you draft a reply. Could that be what is distracting your pc?
/ Forum Upgrade - Any Issues? #644
That one sounds like a local rather than TBN problem. (Because the composition of your reply is local, until you hit 'post').
It's processed locally by code produced by TBN, hence the problem only happens on TBN.
/ Forum Upgrade - Any Issues? #645
Not me. I later discover that the first of my double posts does in fact show its correct timestamp when I eventually see it - but that post was never made visible to me at the time. That first post only becomes visible say five minutes later when I try the alternative leave/stay choice - then immediately I see both posts with timestamps five minutes part. (and the Quick Reply box clears).
Muhammad - Don't paint yourself into a corner with custom programming! :) The providers of VB should be working up a solution for this.
/ Forum Upgrade - Any Issues? #646
vBulletin has always been a train wreck and sometimes custom programming is the only way to fix certain problems or add new functionality.
/ Forum Upgrade - Any Issues? #647
i used to runn BBS systems.
tons of custom scripts.. :(
/ Forum Upgrade - Any Issues? #648
Hi Muhammed, I am a new member and really like this site. I am having one issue. The site will not respond when I try to logout. Yesterday, I was logged in and when I tried to logout, It would not respond. After about 30 attempts, It finally popped up a screen that asked, "are you sure you want to logout"?. At this point, I was able to logout. I am trying desperately to logout now. Can you help me with this issue, PLEASE? HLF
/ Forum Upgrade - Any Issues? #649
What do you want to log out for? Stick around and waste a whole day on here like the rest of us:laughing:
/ Forum Upgrade - Any Issues? #650
I wish I could. I have to go play in the dirt (soil)! Is there anyone who has(had) this issue and is there anyone who can help out???
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2019 John Deere 4044M (A60462)
2019 John Deere...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2014 International Maxxforce DT (A53317)
2014 International...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2014 Vermeer Vac-Tron MC533SDT Heavy Duty Vacuum Trailer (A60352)
2014 Vermeer...
