Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #342
A variation on the technique as 90cummins describes in post #321!
I wouldn稚 go beating on the generator field unit.
Pushing it off is the proper procedure.
90cummins
   / Forum for air cooled diesel engines and clones #344
   / Forum for air cooled diesel engines and clones #345
I got it all apart.
The armature (rotor) came out quite easily, I couldn't find a rod that would fit right, so I whacked it with a rubber mallet a few times and it popped off without much of a fight, soaking in pb blaster for a few days helped too I'm sure.
I then pulled the valve cover off, cylinder head, everything looks clean, no visible damage of any sort, very little carbon buildup, no scoring on cylinder walls, no play in anything.
I didn't open up the crankcase, I'm not sure I should since I don't see anything wrong on the top end, but I'd like to hear some opinions from the experts.
Here are a few pics of what everything looks like.
seems the rest of my pictures are having a hard time uploading, I'll try again a in a bit
xp
If I had it torn down this far I’d open it up.
Pull the piston & check the rod bearing then there are no questions.
Carbon buildup in the ring lands can cause issues better to check now then to go back later.
90cummins
   / Forum for air cooled diesel engines and clones #347
Hi All -
Has anyone got torque specs for these engines? Connecting rod, crankcase cover, head bolts, etc?
Thank you!
   / Forum for air cooled diesel engines and clones #348
Looks like it will be a while before my gasket kit gets here, so I might as well tear the whole thing down and check it all over. I'll post more pictures once I get down into it.
xp
This should help.
90cummins
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
SUV (A59231)
SUV (A59231)
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Forklift (A59228)
Forklift (A59228)
