Forks
/ Forks #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
/ Forks
I'll have to take more pictures. This is the only one I have at the moment. 2 x 4 x 1/4 tubing for the forks. They extend a little longer in the back with a few gussets.
They have a cross tube welded on the top with a 1" ID which slide back and forth on the 1 inch round stock. I'll insert some expended metal and such. Movement is limited to maybe a little higher then what it shows in the above picture. I think the 3pt is rated at 2200 lbs. Not sure what the forks can carry. I did pick up an atv with it, maybe 600 lbs, high enough to just allow tires to clear pavement ( flat surface).
/ Forks #3
Yep, more pics! :) I'm almost ready to consider the same with the unavailability of used forks locally and the silly high prices manufacturer's want for them new.
/ Forks #4
I lucked out last year when I got my forks. Doing some pricing research I found the largest % of price of new forks was for the fork times themselves, frame to them hang them on weren't that much. I checked around with a couple forklift dealers and got 2 pair of used forks for scrap price. OSHA requires forks to be replaced once the tip gets to certain point, so these were scrapped. Bought to frame from dealer, mounted 1 set up for myself, and put the other set up for sale on internet, sold the next day. Ended up having less than $200 in Pallet forks with QA frame for the loader.
John Deere 10KW Generator (A64912)
John Deere 10KW...
2005 Dodge Ram 2500 (A64911)
2005 Dodge Ram...
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
HEAVYEQUIPMENT OFFICE ITEMS (A68842)
HEAVYEQUIPMENT...
