Forks
/ Forks #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
/ Forks
I'll have to take more pictures. This is the only one I have at the moment. 2 x 4 x 1/4 tubing for the forks. They extend a little longer in the back with a few gussets.
They have a cross tube welded on the top with a 1" ID which slide back and forth on the 1 inch round stock. I'll insert some expended metal and such. Movement is limited to maybe a little higher then what it shows in the above picture. I think the 3pt is rated at 2200 lbs. Not sure what the forks can carry. I did pick up an atv with it, maybe 600 lbs, high enough to just allow tires to clear pavement ( flat surface).
/ Forks #3
Yep, more pics! :) I'm almost ready to consider the same with the unavailability of used forks locally and the silly high prices manufacturer's want for them new.
/ Forks #4
I lucked out last year when I got my forks. Doing some pricing research I found the largest % of price of new forks was for the fork times themselves, frame to them hang them on weren't that much. I checked around with a couple forklift dealers and got 2 pair of used forks for scrap price. OSHA requires forks to be replaced once the tip gets to certain point, so these were scrapped. Bought to frame from dealer, mounted 1 set up for myself, and put the other set up for sale on internet, sold the next day. Ended up having less than $200 in Pallet forks with QA frame for the loader.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
3147 (A63117)
3147 (A63117)
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
