Fork attachment build.
/ Fork attachment build. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Building another fork attachment, this one is for my brother-n-law. I won't be going back to his place until next spring, so I have all the time in the world to finish it.:laughing:
It's the same design as mine, just a little bigger.
Tomorrow I'll weld up the taper to the tip of the forks. Then drill holes in the tips, and weld a piece of pipe in the holes.
This is all I have done so far.
/ Fork attachment build. #2
You know for some one who just started welding a couple of weeks ago, you sure are taking on some big projects :)
Isn't that how you learn, jump right in with both feet?:laughing:
/ Fork attachment build. #4
Looks nice! What size tubing do you use for the forks? Do they seem plenty stout?
2" x 4" - 1/4" wall rectangular tubing.
The FEL on my tractor will pick 1,300-pounds. I've had rigging and shackles in the holes in the tips of the forks, and stalled the loader. I use the forks mostly to move my engine drive welders around.
/ Fork attachment build. #6
Looks perfect for your setup. I've been kicking around adding some forks to my hay spear attachment, or I may just build from scratch similar to yours. I'm always thinking of a use for pallet forks around here.
The local feed store gives their pallets away. So I have a lot of things setting on pallets. With the quick release FEL makes it easy to change attachments. A good friend of mine has a Kubota tractor, but no quick release. I've been begging him for years to bring his tractor over so I could build him a quick release. He just doesn't see the need! :confused:
This mornings progress.
Oh a guy can never have to many clamps.;)
/ Fork attachment build. #11
When I built my 4 fork ( double pallet) lifter I cut the angle off the fork tips and welded in a piece of flat bar. Boy do feel dumb now!!
Nice work! I like those clamps too. Never seen any like that before. But then I'm only 64 years old. :)
Terry
/ Fork attachment build. #12
Terry I wouldn't know what to do with such a fancy tool.:confused:
Back in my working days, I carried in my rigging belt a claw hammer, (to beat on shackle pins) side cutter pliers, Crescent wrench, and tape measure.
/ Fork attachment build. #15
Nice quality work! I love watching fab jobs. :hyper:
A set of bucket forks will be one of my winter welding projects.
I changed my mind today. I cut the forks back apart. Going to the metal yard tomorrow morning. I'm going to insert some 3/8" or 1/2" x 1 1/2" flat bar inside the box tube. My brother-n-law's tractor is much bigger than mine. So I think it's a good idea to beef up his forks.;)
/ Fork attachment build. #17
Good call. The temptation is always there to pick something up just using the tips of the forks.
Never had a problem with my 2x4x1/4" sq tubes because the 4 ft forks had to be TOTALLY inserted into the pallets or else the pallet would break. Turf pallets have no bottom boards. Just runners and top boards.
Terry
/ Fork attachment build. #18
I know you only just started welding :rolleyes: but still why not just buy forged forks? They aren't that expensive. Then make the adapter plate for the quick attach or whatever.
/ Fork attachment build. #19
Send me those forks for proper testing. If I can't bend them they are certified tough.
Few years ago I bought a set of warehouse forklift T-1 forks off Craigs list, to replace the box tube forks on my fork attachment. Just waiting until I damage the box tube forks, or they rust out. ;)
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
(INOP) TAKEUCHI TL10V2 SKID STEER (A64280)
(INOP) TAKEUCHI...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
