ford sle 6640 gear problems
/ ford sle 6640 gear problems #1
graeme111
northern ireland
ford 6640 sle
hi.. i have a ford 6640 sle, the problem im having is to do with the gear changing.. the gears are confused,, if its in 4th gear it means its in 1st gear, and when its on 1st gear it means in in 4th,, as going down the gears 2nd and 3rd or ok.. also same problem with 5th till 8th gear,, can anyone help please?????////
/ ford sle 6640 gear problems #2
G'day and welcome the first thing to do is to check and clean all your earthing points and battery terminals also check charging rate as poor voltage can cause probs with these things.
Jon
Jon
thanks for this. i will get to it as soon as i can and see if it helps the problem.. many thanks
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
2022 ALLIANCE NORTH AMERICA AIR MAN SDG 25 GENERATOR (A65643)
2022 ALLIANCE...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
