ford sle 6640 gear problems
/ ford sle 6640 gear problems #1
graeme111
northern ireland
ford 6640 sle
hi.. i have a ford 6640 sle, the problem im having is to do with the gear changing.. the gears are confused,, if its in 4th gear it means its in 1st gear, and when its on 1st gear it means in in 4th,, as going down the gears 2nd and 3rd or ok.. also same problem with 5th till 8th gear,, can anyone help please?????////
/ ford sle 6640 gear problems #2
G'day and welcome the first thing to do is to check and clean all your earthing points and battery terminals also check charging rate as poor voltage can cause probs with these things.
Jon
Jon
thanks for this. i will get to it as soon as i can and see if it helps the problem.. many thanks
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
2023 JCB S3246E...
Metal John Deere Birdhouse (A65583)
Metal John Deere...
Rogator RG1100 (A63689)
Rogator RG1100...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
