Ford 800 Block Cooling Circuit
   / Ford 800 Block Cooling Circuit #1
seth350
Tennessee
55' Ford 800
Hello folks,
I have been working on getting my 55' Ford 800 flushed out and back into tip top shape before winter.
Still having some overheating going on and wanting to see if anyone knows how the circuit flows through the block?
Especially at the drain petcock on the starter side of the block. I first found that it was full of gunk and I am able now to run a piece of two foot weedeater string in and towards the rear of the block. My question, is this port a flow through type, or is where the petcock is located a deadheaded branch off the main circuit?
I tried to rod the hole out towards the front of the block but cant seem to find a hole? I just want to be sure that if coolant is supposed to flow through that port, that I get it cleaned out. If that makes any sense??? :confused:
Basically, is it this way?
--->>>>------COOLANT FLOW FROM REAR OF BLOCK------->>>>[[[[PETCOCK]]]]>>>>-----COOLANT FLOW TO FRONT OF BLOCK----->>>>
OR This way?
--->>>>------COOLANT FLOW FROM REAR OF BLOCK------->>>>[[[[PETCOCK]]]||| DEAD HEADED
   / Ford 800 Block Cooling Circuit #2
Look at your water pump... Water travel path will be evident.
207282 (A52708)
207282 (A52708)
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Cargo Van (A59230)
Cargo Van (A59230)
Jet Ski (A59231)
Jet Ski (A59231)
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
