Ford 4610 trailer conundrum
/ Ford 4610 trailer conundrum
Well, I finally found a trailer. Visiting my Dad last week, his neighbor had a 15' equipment trailer with dual 6000lb axles, the deck measures 84" between fenders. $1400. This is the kind of deal I have been waiting for, for a very long time!
/ Ford 4610 trailer conundrum #62
15'...
The axles are fine but you have no room to place the tea to in a good spot. If you are using a dually 1 ton and a gn trailer, nit a problem... But bumperpull on a half or 3/4 might be an issue getting tounge weight correct.
I can't haul my 4600 on my 26' car hauler for that reason , 30' gn deckover hauls it fine with a 6' mower and a few feet to play with positioning
Well if I even end up having to haul the 4610SU for some reason, it won't be with any implements on it. I'll mostly be using it to haul my Ford 1620 mowing/snow plowing tractor, and other various items. But at least I can fit the 4610SU between these fenders without messing with the tractor tires or ROPS.
/ Ford 4610 trailer conundrum #64
The Su model will be a lil easier, lighter front end
2023 Case TV380 (A62177)
2023 Case TV380...
2004 International 7400 C&C 017797 (A62613)
2004 International...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
2013 CATERPILLAR...
211299 (A62131)
211299 (A62131)
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
