Ford 3910....no fuel at injectors. Please help!
   / Ford 3910....no fuel at injectors. Please help! #41
I got mine put back together and it works they arent as scarey to rebuild and quite simple once I figured out exactly how they work
I sent you a message reply to it with contact info if you want to talk about it
   / Ford 3910....no fuel at injectors. Please help! #42
The head has 2 pistons in it that run on rollers off the cam ring if they freeze up and stop moving you will get zero pressure out of the hydraulic head
I found a semi-local company that rebuilds pumps. D&C diesel in Falmouth KY. $485 to rebuild my pump, they also have detailed instructions on their website for removal and installation for specific models. Ill try to tackle removing it this weekend.
Well I got the pump off without too many problems. D&C's instructions sure are handy. Good news is that the head isn't seized. That will save a few bucks on the rebuild. Turn around time should be less than a week. I appreciate the help from everyone and will keep you updated.
The pistons inside the head were seized. D&C blamed it on water and algae in the fuel.
I got my injection pump back and everything put back together last night. I was just about to try cranking it over and I guess I over tightened my glass sediment bowl and busted it. Just my luck! Luckily the local shop had one in stock...
She lives! Thanks for the help everybody!
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Kelly Ryan Bagger (A50774)
Kelly Ryan Bagger...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2014 John Deere 6125M (A50120)
2014 John Deere...
