Ford 3910....no fuel at injectors. Please help!
   / Ford 3910....no fuel at injectors. Please help! #41
I got mine put back together and it works they arent as scarey to rebuild and quite simple once I figured out exactly how they work
I sent you a message reply to it with contact info if you want to talk about it
   / Ford 3910....no fuel at injectors. Please help! #42
The head has 2 pistons in it that run on rollers off the cam ring if they freeze up and stop moving you will get zero pressure out of the hydraulic head
I found a semi-local company that rebuilds pumps. D&C diesel in Falmouth KY. $485 to rebuild my pump, they also have detailed instructions on their website for removal and installation for specific models. Ill try to tackle removing it this weekend.
Well I got the pump off without too many problems. D&C's instructions sure are handy. Good news is that the head isn't seized. That will save a few bucks on the rebuild. Turn around time should be less than a week. I appreciate the help from everyone and will keep you updated.
The pistons inside the head were seized. D&C blamed it on water and algae in the fuel.
I got my injection pump back and everything put back together last night. I was just about to try cranking it over and I guess I over tightened my glass sediment bowl and busted it. Just my luck! Luckily the local shop had one in stock...
She lives! Thanks for the help everybody!
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
Skid steer auger plate (A50322)
Skid steer auger...
Hay Forks (A50515)
Hay Forks (A50515)
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
2012 RAM 5500 (A52472)
