Ford 3000 clutch
   / Ford 3000 clutch #1
ddavis317
Ford 3000 Gas
Hello, My ford 3000, clutch seems either worn or out of adjustment. When I depress it, it is not engaging, and won't go into gear. Are these hydraulic? Also how do I adjust? Any info is much appreciated.
Thanks
   / Ford 3000 clutch #2
They are not hydraulic, look below the pedal and you will see a threaded rod with a clevis on each end. Remove one end of it and adjust the rod until you get an inch or two of free pedal travel. If adjusting the linkage does not fix your problem then it maybe time for a clutch.
   / Ford 3000 clutch
Thanks John, I am hoping it just needs adjusted, I have had it for about 10 years, and it had a new clutch when I got it. Thanks again, with fingers crossed.
   / Ford 3000 clutch
Well, it wasnt the clutch adjustment. Had a friend check it out, found mouse nest.
Thanks
   / Ford 3000 clutch
Not the the clutch adjustment, mouse adjustment.
   / Ford 3000 clutch #6
Industrious rascal for sure
   / Ford 3000 clutch
So does anyone know the torque specs for the flywheel to the mount, and the pressure plate to the flywheel? I am getting different results on my searches. Thanks in advance.
   / Ford 3000 clutch #8
Flywheel to engine should be around 75-85 ft. lbs. and the clutch to flywheel around 20 ft. lbs. I would just Google a bolt torque chart, it will be close enough for what you are working on. Just be sure you select the correct grade of bolt spec.
   / Ford 3000 clutch
Hi John, thanks for info, I believe they are going to use old bolts.
   / Ford 3000 clutch #10
Yes but he's talking grade 5 or grade 8 or whatever you're going to get a different recommended torque value which also changes based on thread pitch
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
