Ford 3000 clutch
/ Ford 3000 clutch #1
ddavis317
Ford 3000 Gas
Hello, My ford 3000, clutch seems either worn or out of adjustment. When I depress it, it is not engaging, and won't go into gear. Are these hydraulic? Also how do I adjust? Any info is much appreciated.
Thanks
/ Ford 3000 clutch #2
They are not hydraulic, look below the pedal and you will see a threaded rod with a clevis on each end. Remove one end of it and adjust the rod until you get an inch or two of free pedal travel. If adjusting the linkage does not fix your problem then it maybe time for a clutch.
/ Ford 3000 clutch
Thanks John, I am hoping it just needs adjusted, I have had it for about 10 years, and it had a new clutch when I got it. Thanks again, with fingers crossed.
/ Ford 3000 clutch
Well, it wasnt the clutch adjustment. Had a friend check it out, found mouse nest.
Thanks
/ Ford 3000 clutch
Not the the clutch adjustment, mouse adjustment.
/ Ford 3000 clutch
So does anyone know the torque specs for the flywheel to the mount, and the pressure plate to the flywheel? I am getting different results on my searches. Thanks in advance.
/ Ford 3000 clutch #8
Flywheel to engine should be around 75-85 ft. lbs. and the clutch to flywheel around 20 ft. lbs. I would just Google a bolt torque chart, it will be close enough for what you are working on. Just be sure you select the correct grade of bolt spec.
/ Ford 3000 clutch
Hi John, thanks for info, I believe they are going to use old bolts.
/ Ford 3000 clutch #10
Yes but he's talking grade 5 or grade 8 or whatever you're going to get a different recommended torque value which also changes based on thread pitch
2009 Kubota RTV1140 (A57149)
2009 Kubota...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
2019 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2019 Posi Track...
Land Pride 80in Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride 80in...
