Ford 2 N
/ Ford 2 N #1
slim357
Bronze Member
Ford 4110
Does the camshaft just slide out or is it held in by something else?
/ Ford 2 N #2
It will slide out just make sure all the tappets are up against the block so one of them does not hang on the cam as you try to remove it. I usually flip the block upside down before removing the cam. On a side note there are NO cam bearings if that is the reason you are removing it thinking to replace them.
/ Ford 2 N
Thanks for the information. Lifters are all rusted in place, I got them to each move to top of lobe so hopefully will come out
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
