Ford 2 N
/ Ford 2 N #1
slim357
Ford 4110
Does the camshaft just slide out or is it held in by something else?
/ Ford 2 N #2
It will slide out just make sure all the tappets are up against the block so one of them does not hang on the cam as you try to remove it. I usually flip the block upside down before removing the cam. On a side note there are NO cam bearings if that is the reason you are removing it thinking to replace them.
/ Ford 2 N
Thanks for the information. Lifters are all rusted in place, I got them to each move to top of lobe so hopefully will come out
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
iDrive TDS-2010H...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
John Deere 4520 (A60462)
John Deere 4520...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
