Food plot and wet ground question
/ Food plot and wet ground question #1
Mitigator33
Eastern Alabama
John Deere 5083E
I am trying to get my spring plots in. The cutoff for most of the seed in my zone is 2nd week of March. However, the weather has not cooperated. I have 5 plots that I am planting smaller seed such as alfalfa and clover as well as some chicory. The plots are so wet when I disked it turned very good and the ground is staying muddy to the point my tractor causes ruts. I broadcast my lime a few weeks back and disked it in as well as my fertilizer. When I went to sew seed today my cultipacker turned into a mud roller and was not useable.
My land is 1.5 hrs away so I can't waste trips and I don't have that much time. So today I just packed 2 fields as best I could given the soil condition then broadcast seed with hand spreader and left it. I was planting clover. The reason for not doing a follow up cultipacker was the mud clumping and sticking to my packer. I did not want to just rearrange seed. To compensate for the potential poor germination rate I added a little more seed.
The question is did I do the right thing here?
The next problem is that it is going to rain 2 more days this week and the 3 fields that were so bad I left them alone have to be planted next weekend. They have already been limed and disked as well as fertilized so I am just going to hit them with a packer and or pull behind fence drag then seed them and leave alone. I plan on upping my seed again.
How does that plan sound and can I still expect good results?
Thanks
/ Food plot and wet ground question #3
I think you have done the best you can in you situation. Your only other option is to let it dry out, which may not be a bad idea.
/ Food plot and wet ground question #4
The seed probably got rained in to some extent, if that makes you feel any better. I avoid working wet gound as much as possible because none of my equipment works well in the mud. It is not late enough that your seeds will sprout and then get burnt off by hot sun, so that is a good thing too.
/ Food plot and wet ground question #5
"The cutoff for most of the seed in my zone is 2nd week of March. " :confused:
I'm not from alabama! So is some one telling you when you can plant and can not plant? The Game Department, county agent? :confused2:
Just recommended seed planting dates for my area in Alabama. I also talked to ag extension office and seed manufacturer.
/ Food plot and wet ground question #7
I think it will be just fine.
Oldstuff
/ Food plot and wet ground question #8
If a field is as wet as you say then I wait till it dried out some. It's not like your harvesting the food crop but what it brings to you!
/ Food plot and wet ground question #9
It will be interesting to see what the results will be. My biggest concern would be with planting in muddy conditions is a lot of times it will develop a crust once it dries out and the seedlings have a rough time pushing through. You might be Ok though since small seeds are generally just broadcast and packed so the wet soil might actually help with your seed to soil contact which would improve germination. Keep us posted on the results so I know if I can plant when the soil is like this. :D
/ Food plot and wet ground question #10
Planting in mud---you're wasting your time and seed. Let the field dry and then plant. If it's a little late in the season by the time you can plant, why worry. Either the crop makes it or it doesn't. We're all at the mercy of the weather:eek:. I'm sitting here with a cover crop on my 6 acre hayfield and only about 9 inches of rain so far in the wet season (Nov thru May here). Normal is 18" per year. 60% chance of rain late today and tomorrow. Hope it shows up this time.
/ Food plot and wet ground question #11
You can also just wait and plant those types in the fall, September is usually the time here in the South. Worst case, plant something like Milo or Sunflowers, then plow that in in last week of August.
/ Food plot and wet ground question #12
Mudding in plots can cause many problems. Crusting and compaction jump to mind. Another consideration with wet soil is the development of air pockets in the soil structure. The dirt won't crumble as it does when it is dry causing large pockets of trapped air. Applying some amendments to wet soil can be detrimental also. Inconsistent mixing at incorporation.
You never want to work ground that is too wet! If nothing else you can cut it with a disk once to let it dry out but you will end up with large clumps when it dries out.
/ Food plot and wet ground question #13
Thanks
Don't worry about the date, you can plant a little later and every thing will be ok. I planted corn last year and in Michigan we got a ton of rain, I had to replant, so my advice would be to wait, to much mosture will drowned the seed. My father one year planted corn on the 4th of July weekend, he used it to feed cattle in teh fall and winter.
