Flushing Coolant on 4100
/ Flushing Coolant on 4100 #1
Bucks County, PA
JD 4100 - sold
Does anyone have a clear picture that displays where the coolant drain plug is on the block of my 4100? The owners manual isn't helpful although there does appear to be a possible plug back behind the fuel filter housing - not easily accessible though.
/ Flushing Coolant on 4100 #2
I cant speak for the 4100, but on my 4110 and 455 the plug is behind the fuel filter bowl. It is much easier to unbolt the bowl/filter and then unscrew the coolant plug.
Hope this helps!
I was hoping the bowl wouldn't have to be removed. I wonder if there is any other way to access the plug.
/ Flushing Coolant on 4100 #5
If you're draining the coolant anyways, have you thought about putting a block heater in? That's the ideal time to do it.
Just a thought.
/ Flushing Coolant on 4100 #6
I did mine today not removing anything. I used a 17mm 6pt socket on a wobbler (partial universal) with a 6” ext. easy peasey but for install I used the socket/wobbler in left hand & a 12” scraper(or screwdriver) in right hand from below to “center” socket/bolt to screw in..viola flushed & drained 3 times. :)
2015 CATERPILLAR 232D SKID STEER (A65056)
2015 CATERPILLAR...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2013 CATERPILLAR D6N LGP CRAWLER DOZER (A65056)
2013 CATERPILLAR...
2023 Hustler LX890 235 Gallon Sprayer Tractor Attachment (A66734)
2023 Hustler LX890...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
2017 Ford F-150 Crew Cab Pickup Truck (A68183)
2017 Ford F-150...
