Flushing Coolant on 4100
/ Flushing Coolant on 4100 #1
Bucks County, PA
JD 4100 - sold
Does anyone have a clear picture that displays where the coolant drain plug is on the block of my 4100? The owners manual isn't helpful although there does appear to be a possible plug back behind the fuel filter housing - not easily accessible though.
/ Flushing Coolant on 4100 #2
I cant speak for the 4100, but on my 4110 and 455 the plug is behind the fuel filter bowl. It is much easier to unbolt the bowl/filter and then unscrew the coolant plug.
Hope this helps!
I was hoping the bowl wouldn't have to be removed. I wonder if there is any other way to access the plug.
/ Flushing Coolant on 4100 #5
If you're draining the coolant anyways, have you thought about putting a block heater in? That's the ideal time to do it.
Just a thought.
/ Flushing Coolant on 4100 #6
I did mine today not removing anything. I used a 17mm 6pt socket on a wobbler (partial universal) with a 6” ext. easy peasey but for install I used the socket/wobbler in left hand & a 12” scraper(or screwdriver) in right hand from below to “center” socket/bolt to screw in..viola flushed & drained 3 times. :)
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2004 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2004 Harmon Steel...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A67147)
2005 MACK CXN613...
IRANCH Tire Balancing Machine (A64194)
IRANCH Tire...
2019 Chevrolet Tahoe SUV (A64194)
2019 Chevrolet...
