Loader float sticks
/ float sticks #1
fire526
Irons Michigan
LS XR4046HC
Anyone having a problem with float mode on loader sticking? I have a 4046 and if I push the joystick all the way forward into float I can hardly get it back out.
/ float sticks
checked everything except for pulling the spool apart. Just seems like something is catching when it goes in. I guess I will have to call the dealer
/ float sticks #4
Does it come out of float when you pull it back and feel a spot you have to push it through or does it not come out of float. If it's the comes out of float and have to push through a spot that is normal.
/ float sticks
I have to put both hands on it and jerk it back extremely hard. Almost impossible. I unhooked the cable at the hydraulic unit and had to use a screw driver to pry it back out of float. Its getting worse.
/ float sticks #6
Had trouble with mine staying in float along with locking not staying in. Dealer fixed at 50hrs service, no problem since.
/ float sticks #7
Definitely sounds like a physical, mechanical problem inside the valve itself, or wherever the ball/spring/detent/whatever mechanism is.
/ float sticks #8
Mine does it as well, Gotta jerk it out of float. Haven't pulled the spool apart yet.....
/ float sticks #9
Try pulling the cup(s) off the bottom of the spool(s) and add some grease to the detent parts...
/ float sticks #10
My guess is, its not the spool itself, but the control joystick. Mine was sticking like that, and it needed a little lube.
Land Pride 3-Pt Rotary Mower (A66408)
Land Pride 3-Pt...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2022 EZ-GO ELITE...
