Loader float sticks
/ float sticks #1
fire526
Irons Michigan
LS XR4046HC
Anyone having a problem with float mode on loader sticking? I have a 4046 and if I push the joystick all the way forward into float I can hardly get it back out.
/ float sticks
checked everything except for pulling the spool apart. Just seems like something is catching when it goes in. I guess I will have to call the dealer
/ float sticks #4
Does it come out of float when you pull it back and feel a spot you have to push it through or does it not come out of float. If it's the comes out of float and have to push through a spot that is normal.
/ float sticks
I have to put both hands on it and jerk it back extremely hard. Almost impossible. I unhooked the cable at the hydraulic unit and had to use a screw driver to pry it back out of float. Its getting worse.
/ float sticks #6
Had trouble with mine staying in float along with locking not staying in. Dealer fixed at 50hrs service, no problem since.
/ float sticks #7
Definitely sounds like a physical, mechanical problem inside the valve itself, or wherever the ball/spring/detent/whatever mechanism is.
/ float sticks #8
Mine does it as well, Gotta jerk it out of float. Haven't pulled the spool apart yet.....
/ float sticks #9
Try pulling the cup(s) off the bottom of the spool(s) and add some grease to the detent parts...
/ float sticks #10
My guess is, its not the spool itself, but the control joystick. Mine was sticking like that, and it needed a little lube.
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
