Tires FLAT TIRES
/ FLAT TIRES
Don't care for fix a flat type products.
Some of them fill the tire with explosive gases.
They also become a gummy gooey mess that is a bear to clean up inside the rims
/ FLAT TIRES
</font><font color="blue" class="small">( As I've said before, a couple of years ago my record was 13 flats in one year, on two tractors ... all in the front. That was preSlime. Since then, I've not had one on a treated tire ... touch wood fast. But, as far as your theory goes, I have had flats on the back too, only 3, I think. They are a booger though as there is nobody around here that will come out to fix them anymore because of liability issues. It's up to you to get it off, get it in, get it fixed, get it reinstalled. Oh, I hate a flat on the rear!!!!!!!! /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif )</font>
It seems like the casings and the tread are pretty thin and soft on the front tires of my power kraft l&.g tractor.
They quickly become like a pin cushion for briers and short thorns.
Once that happens they're shot and must be replaced as you can't even put a tube in them.
It isn't long before a new tire becomes a pin cushion and the whole cycle starts all over again.
/ FLAT TIRES #23
<font color="blue"> It's been my experience that every flat tractor tire I have had has been a front tire.
What's yours? </font>
It's been my experience that when I get a flat tire, it's only flat on the BOTTOM! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ FLAT TIRES #24
</font><font color="blue" class="small">( Haven't had a flat tire since we started using Multi-Seal. How do you like fixing flat tires /forums/images/graemlins/frown.gif )</font>
Mike, tell me about Multi-Seal? pros? Cons? Cost????
Bob
/ FLAT TIRES #25
Bob these folks can tell you way more about the product than I can Multi-Seal
All I know is IT JUST WORKS /forums/images/graemlins/grin.gif
If you plan to add some to whichever tractor you purchase I will be more than happy to loan you the special pump to get it in your tires. $70.00 savings to you!
/ FLAT TIRES #27
</font><font color="blue" class="small">( Bob these folks can tell you way more about the product than I can Multi-Seal
If you plan to add some to whichever tractor you purchase I will be more than happy to loan you the special pump to get it in your tires. $70.00 savings to you! )</font>
Did you use Armor-Seal or Heavy Duty ?
Bob
/ FLAT TIRES #28
I used the heavy duty sealer myself..
I purchased a 5 gallon pail and have about 1/2 gallon left. I'll most likely add that to what's already in the rears before next winter.
/ FLAT TIRES #29
Obviously it's random betweem front and rear depending on what you hit or run over. In my case it's ususally rear tires. I attribute it to the face that they are many times more expensive to repair. Fronts may go first since they are weaker tires and hit whatever first.
Andy
/ FLAT TIRES #30
Who gave you the special pump?
Bob
/ FLAT TIRES #31
</font><font color="blue" class="small">( Obviously it's random betweem front and rear depending on what you hit or run over. In my case it's ususally rear tires. I attribute it to the face that they are many times more expensive to repair. Fronts may go first since they are weaker tires and hit whatever first. )</font>
I've had three flats on my left front tire only.
I've torn pieces of lug on the rears, but never flattened them.
John
/ FLAT TIRES #32
<font color="blue"> Who gave you the special pump?
Bob </font>
No one gave me the pump Bob, I paid Multi Seal $70.00 for it. When you get enough flat tires on a tractor no price will be to high to eliminate them.
As I said you would be most welcome to use it for free if the need arises,
/ FLAT TIRES #33
I've had flats on both fronts. One thorn and one nail, I Slimed them suckers and no more problems so far. I bought the tube type Slime from TSC.
/ FLAT TIRES #34
I had 4 or 5 flats last year all on the front tires. Put in slime and no more flats.
That was on my old tractor. No slime or flats on my new one... yet.
Dragline Bucket (A65640)
Dragline Bucket...
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
275 Gal Front Mounted Tank w/Bracket (A64127)
275 Gal Front...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
