Flail on a mini excavator
   / Flail on a mini excavator #1
fixit
Bronze Member
Devon UK
Iseki 2160f
Hi all i'm would like a little advice from any one that could help i have a 3 foot wide flail deck from a turner walk behind flail mower
simular to a ferris
that i have been thinking about fitting on to my kubota KX71-2 digger as i have i lot of steep banks that i can only cut with a weed wacker And it is wearing thin
Fabricating the brackets and linkages is straight forward enough for me but i don't know much about hydrualics:confused2:
So the question is how would i decide what size / flow rate hydrualic motor to
fit on to it
Many thanks in advance Chris:thumbsup:
   / Flail on a mini excavator #2
Do you know the HP of the engine that powered the deck? Do you know the rpm of the rotor? The displacement of the hyd motor , and GPM's will determine the speed. Small displacement , high speed, and large displacement low speed.
7 GPM's and 4 cu in, will turn the hyd motor at 404 rpm. 4 cu in and 2500 psi, will develop about 1592 in lbs
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
UNUSED RAYTREE RMLL60-60" HYD LAND LEVELER (A60432)
UNUSED RAYTREE...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2844 (A58376)
2844 (A58376)
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
