Flail Mower flail mower
/ flail mower #1
davidseaquist
Escondido California
2005 Ingersoll Rand Bl370b
I got a 48" kubota flail mower with the purchace of my b7100 tractor. It has been used some of the blades/knifs are missing and the gear box shaft that the pto hooks on to is wobbly I haven't tried to fix it yet. What is the application for a flail mower. thanks david.
/ flail mower #2
<font color="blue">( What is the application for a flail mower. ) </font>
Cutting grass, weeds, etc.
/ flail mower #3
I've got a Mott Hammerknife flail mower on an old 47 farmall cub. It's also a 4 footer. I don't use it anymore but when I did I was quite impressed with its perfomance. For the small amount of horsepower that cub has, the mower would go through almost any weeds and grass you point it at. I mowed stuff 5 ft. tall with it.
Kevin
/ flail mower #4
Flail mowers are not meant for heavy or tall brush. They will give a great clean cut and NOT throw rocks and debris. This is why you see them used around schools and businesses where safety is of prime importance.
/ flail mower #5
There are actually different types of flail mowers with differing purposes: light duty, medium duty, and heavy duty. Light duty models use "knife blades" which cleanly cut grass stems and leave a "finish cut". Heavy duty models use heavy "hammer blades" which simply break whatever vegetation they hit (up to 1.5 or 2 inch dia. stems) and leave a "rough cut". Medium duty is a compromise between these types.
Flail mowers are relatively expensive and tend to be used commercially more than by private individuals. The light duty are used by grounds keeping crews, golf course maintenance crews, etc. while heavy duty are more typically used by highway crews on shoulders with rough thick, possibly overgrown, vegetation.
Because flails are not aggressively marketed to private individuals, the distinction between the differing types is not highly publicized. Often a person will come into contact with one type and assume that all flails are like that type. This is understandable because the industry does not go out of its way to inform us.
/ flail mower
Tom thanks for the information on flail mowers. Mine is lite duty with the knifes bent at a 90 degree angel, and has a roller on it what is the purpose of the roller ?
David
/ flail mower #7
I bought a flail mower to pull behind my ATV -- came with a 14 HP Honda engine and was built solid. But it hasn't worked out for me.
While most of my problems probably don't apply to your situation (given yours is pulled by a tractor and fun off a PTO) the one general short-fall that may apply was clearance. The front lip of it would catch on a tuft of grass and cause problems including flipping over.
Also, as I found out too late, the blades were made for cutting lawns not fields of grass and weeds so it wouldn't handle anything too tall. If I were mowing a ball field it would be great but that wasn't the case. Can't blame the horse for not being a cow -- it just wasn't the right tool for the job.
/ flail mower #8
Who makes a flail for an ATV? I have seen several finish mowers for ATV but not a flail. Swisher and Bush-hog come to mind.
/ flail mower #9
Clean Cutter should have the replacment flails and at a good price. I have ordered from them them before. they were about 1/2 the price of JD.
/ flail mower #10
Alamo -- the same people who make the ones seen along roads and in parks, except with a gas engine mounted on top. They had stopped making them just before I bought mine (2001) but I found two at a warehouse in Bradford, PA.
Before buying I had exchanged info at ATVing.com with guys who use ATVs in landscaping businesses. They all said the Swisher-types just tear themselves apart so I went looking further. A neighbor in the country had a flail mower and liked it (but lost it in a divorce) so I thought it might work for me.
But as noted above, it just hasn't worked well in my situation. I put a ball hitch on it, got bigger tires, and installed anti-scalp rollers but it still is not the right tool for the job.
Also, I think I can safely say that an ATV makes a poor tractor. The main problem is keeping it at a steady pace -- its either surging ahead or bogging down, plus your thumb gets tired, the engine gets hot, your back hurts, your neck gets sore from looking behind, and so on.
I rest my case.
Thanks,
Rod
/ flail mower #11
I had a bush-hog cutter for my ATV at one time. Note the word HAD. I concluded it wsa not good for much, definately not good for what I was doing. More or less gave it away. I am a big fan of a flail for cutting unkempt areas.
/ flail mower #12
Dave the roller in front is for anti-scalp. I use an 88" Alamo with medium blades to mow about 7 acres of lawn and another 7 acres of fields (once or twice a year). I love the flail mower. Used to mow the lawn with a finish mower and the fields with brush mower ... the flail does a much more efficient job on both ... Scozz
/ flail mower
thanks for the info on the roller I hope to fix the flail mower up and play with it this summer. David
/ flail mower #14
David,
www.flailmaster.com is another good place to buy parts online. Very knowledgeable and nice people.
Good Luck,
Russ
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
