Flail mower drive
/ Flail mower drive #1
joes_427_vette
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Bought a used 6' flail mower with a broken gear drive. Apparently the small alum housing didn't hold alot of oil and the small offset gear arrangement ran dry. A new gear drive is very expensive and by counting the teeth it is geared 3 to 1 on the pto. I have a new holland 1 to 1 gearbox with pto shaft that fits like it belongs. There is not enough room at the drive shaft to get the proper speed with a large pulley. Any ideas how to get the proper speed ? It cuts short grass 1 to 1 but not heavy tall grass.... needs the rpm for a clean cut.
/ Flail mower drive #2
Don't know much about the NH equipment, but I wonder if a different gear set could be installed in that NH housing? Maybe a check with NH engineering could help? Sure would be nifty if that worked out for you.
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2009 CHEVROLET IMPALA CAR (A66091)
2009 CHEVROLET...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
