Fixing another gravel drive
   / Fixing another gravel drive #1
whynot162
Amboy WA
Rhino 324
So I live on a steep hill in the Pacific northwest. The recent rain has washed ruts in the road and the gravel down the hill.
Before I have just pulled the gravel back up the hill filling it in with the box blade.
I noticed this year that the road is now looking lower than the surrounding area.
Can I drag the dirt from the side of the road onto the road to lift it and make a better ditch along the road? Then dead the gravel back up over that and add a load of rock. Or is adding the dirt a bad idea
   / Fixing another gravel drive #2
I share a 1/3 mile common lane with a retired farmer. We usually regrade and refresh the ditches on each side of the road after major storms (we just got 4" in 24 hrs). I'm still learning how to maintain the drive. Personally I prefer what they here call 2A modified (we called QP or quarry process) which has the dust/finings. I think it packs and wears better. IMO some dirt in the gravel makes it a better base, but the key is to maintain a crown and ditches.
We use a rear blade most often to regrade and fix the ditches. I do have a BB for moving material.
   / Fixing another gravel drive #3
Bad time of year to add dirt in the PNW, rain is here...
Sounds like you need to crown in the spring/summer and do the ditches. At this point in the year all you might be able to do is fill with coarse gravel to let the water run through it ... until it freezes if you are high enough up.
Hmm; crowning is the method of having the center at the highest point and sloped down towards the ditches so water does not pool and sit. It is used in areas that get a lot of rain and seasonal water movement, in case anyone wants to know.
   / Fixing another gravel drive #4
My driveway is about 500' long and has a serious elevation drop in part of it. I used the superelevated curve shown by the previous poster. It worked out great. Here we use what is called 3/4 process with dust. We had a really abnormal year of heavy rains and the driveway stayed intact with no erosion.
   / Fixing another gravel drive #5
No matter what the road is used for ditches make the road. With out ditches collecting and moving water away your road is the ditch and susceptible to wash outs, mud, pot holes and major erosion.
You need ditches on the side of the road and the surface to be higher than the surrounding area. How you do this is different in different situations.
   / Fixing another gravel drive #6
I quit trying to crown my long steep driveway many years ago,
I also use the superelevated curve as shown on my two turns.
A crown enough to shed the water off the steep driveway would not be driveable in the winter.
I place "water cuts" in my driveway.
Narrow trenches dug at an angle across the driveway to catch and funnel the water off to the ditch
or over the bank, they work and keep the driveway intact with much less gravel lose
then crowning could ever achieve.
Crowning a drive will work good on flat drives or minor slopes not on steep slopes.
I can put a 3" wide by 3" deep trench across the driveway at a downhill angle with the tractor in nuetral
and riding the brakes to keep it slowed down.
The hard way to do them or even to just clean out existing cuts.
   / Fixing another gravel drive #7
My gentle driveway crown and relatively shallow ditches had done a great job of shedding water for several years. But then we got over 6 inches of rain in a single day (most coming in a gnarly 3 hours of deluge). The crown couldn't shed it all (especially on my steepest hill) and the ditches didn't have nearly enough capacity. Most of my top, smaller gravel got washed right off the road, serious bummer when I woke up the next day.
Repaired and no problems since; didn't buy any more gravel. Looks pretty nice again now.
My thread on it:
   / Fixing another gravel drive #8
Have to be cautious doing that in the PNW, the ground is mostly either red/brown clay or sand underneath, cutting across in those conditions will cause significant erosion channels and wipe out any road within a few hours if enough rain comes down.
If the op is on rock, they would be fine.
Edit: that method works on blue clay as well since it is hydrophobic.
   / Fixing another gravel drive #9
I just moved to a place that has about 2 miles of common and private roads/driveway, Some of it has no top coat, just poor quality crusher run gravel that seems to get worse rather than better when working it. The common driveway which has a proper top coat of 3/4 to dust is shared primarily by three homes is badly wash boarded in places. The tools I have are a box blade, a drag harrow, back blade and a rock rake. I worked on part of it a few weeks ago with the harrow and box blade and improved it a lot, but my neighbor worries that he won't be able to get his truck home if I work on the wash boarded hills. ( I think if I smooth the washboards his truch wiuld have a less tendency to axle hop) It is near desert country here with a maximum of 15" of rain annually plus the road is 20 feet wide in places so crowning would be difficult and not all that necessary. What do you all recommend as the best technique to renew the surface given the attachments and my old Ford 1715
   / Fixing another gravel drive #10
I'd leave it be. He will never be happy with the results so don't bother fixing it. Fix the parts that are related to your section and let him worry about his section. See first sentence for his section work.
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2014 Ford F250 (A55973)
2014 Ford F250...
WHIRLPOOL STAND UP FREEZER (A57192)
WHIRLPOOL STAND UP...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2007 Yamaha Rhino 660 (A55315)
2007 Yamaha Rhino...
