Buying Advice First Tractor
/ First Tractor #41
First tractor was a 1962 Farmall 504 diesel. I put a new Koyker loader on it in 2008? Still have that tractor.
CT
/ First Tractor #42
I am looking for 4wd tractor with a loader.
I have just under 9 acres, about half wooded, and would like to run the following attachments:
  • Tiller
  • Wood splitter
  • Box blade
  • Wood chipper
I believe I need 20-25 HP at the PTO to run the tiller.
Eventually I may want to use other attachments so would prefer to not limit myself, but I don't have enough knowledge to know how to mitigate that.
I would prefer something old that can effectively/easily run a loader without custom work (welding up custom brackets, third party hydraulics, etc).
The reason I want to go with something old is price, I don't have $35K+ to drop.
The flip side to buying used is that you need mechanical skills to keep them running (more so than with a new one). Sadly, I am not gifted in that way. As others have said, you picked a bad time to want a used tractor. I am going to buy new.
/ First Tractor #43
For non-commercial use, I'd argue the only skills needed to keep a solid 80s-90s vintage diesel tractor going are the ability to change fluids, replace filters, and find/grease zerks. That's been my personal experience over the last year and a half with my two fords and around 600 hours of not exactly easy work. Similar situation for the old man I work with and his deeres over the last 5 years.
/ First Tractor #44
Maybe add skills to store it out of the weather. :cool:
You are correct, the old girls run pretty much trouble free if you do what you describe.
2021 John Deere 5100E (A64126)
2021 John Deere...
3097 (A63117)
3097 (A63117)
Mineral Feeder (A66408)
Mineral Feeder...
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
3 BottomPlow (A62613)
2022 EZ-GO ELITE...
