Buying Advice First Tractor
/ First Tractor #21
Here is a LS tractor think its the smallest
that they make:
LS Mini Tractor$ 10,099 USD (Approx)
  • 3 – cyl diesel engine
  • Independent PTO
  • PTO On & Off switch
  • Auto PTO ON & OFF System
  • Powerful Three-point hitch
  • Water Cooled diesel engine
then you have the attachments to purchase IMHO
you would have to double your budget to get what
you want
willy
/ First Tractor #22
Thank you for taking the time to write this all out, this is very helpful. "And when you finally get it all working like new you will be old and wise enough to appreciate that it will keep on going on for another generation". This is the goal and well put.
Could you help my understand:
What is the difference between ag and compact tractors? I had the general impression that all tractors were ag tractors.
Does a Cat II hitch provide more options or just more power? Is there a significant price difference between attachments for a Cat I vs a Cat II?
I have come to understand that 4wd and power steering is basically non-negotiable when running a loader. Can you confirm this, and can I assume that generally, 20-30 year old tractors come with power steering?
When it comes to name brands, I've landed on John Deere, Massey Furguson, Kubota, and New Holland as the ideals for parts availability. Can this be expanded?
I asked this above in another response, but what is the best method to go about getting parts? Is there a RockAuto for tractors to your knowledge?
Can you give your thoughts on hydro static vs gear terms of the trade off if any between longevity, maintenance/parts, and easy of operation with a loader or tiller.
The 1970-80s Ford tractors are worth considering (before they became New Holland) and parts availability is still good.
/ First Tractor #23
Last I heard Kubota was still offering zero or low interest loans. If it was me, I’d either pickup a new L2501 with a good financing rate or pay cash for an old JD 850/950 with 4WD and loader.
/ First Tractor #24
I have just under 9 acres, about half wooded, and would like to run the following attachments:
  • Tiller
  • Wood splitter
  • Box blade
  • Wood chipper
I would like cost to be under $10k including some/all the attachments.
6/1/2022
DappleDoxieStaff
I have bought a 1955 Oliver Super 55 with four implements, delivered, for $2,800. (No Loader) With the tractor I am getting a disk, harrow, planter and sprayer.
My mechanic is rolling his eyes because the Oliver is 67 years old, an orphan brand, and it is gas.
Is he going to be right in the long run? Did I want a diesel??
Oliver Super 55 Power
Drawbar (claimed):23.3 hp
17.4 kW
PTO (claimed):32.65 hp
24.3 kW
Drawbar (tested):29.60 hp
22.1 kW
Belt (tested):34.39 hp
25.6 kW
Mechanical
Chassis:4x2 2WD
Brakes:mechanical disc
Open operator station.
Transmission:6-speed unsychronized gear
Dimensions
Length:120 inches
304 cm
Height:71 inches
180 cm
Operating weight:3,400 lbs
1542 kg
Ballasted weight:5,500 lbs
2494 kg
Front tread:48 to 76 inches
121 to 193 cm
Rear tread:48 to 76 inches
121 to 193 cm
The compact tractor era functionally began when Henry Ford licensed Harry Ferguson's tractor and Three Point Hitch design in 1939. The tractor industry uniformly adopted the Three Point Hitch after 1955, when Ferguson's patents began to expire and his tractor and Three Point Hitch design were available to industry participants open source.
Improvements in approximate order: Power Steering, "live" PTO then "independent" PTOs, Rollover Protection, 4-WD, Industrial Tires, Loaders, later Loaders and attachments with SSQA, synchromesh geared transmissions, diesel engines, heavier tractors with Category 2-3-4-5 TPH, Landscaping tractors of <2,000 pounds bare tractor weight, hydrostatic transmissions, shuttle shift gear transmissions, cruise control, Cabs with heat and AC. And, continuously, shields separating operator from moving parts.
I blundered across this list of defunct tractor manufactures on Wikipedia.
Tough business.
/ First Tractor #25
I live in rural VA.
Add rural VA to your T-B-N profile.
Compact tractors weigh from 2,000 to 6,000 pounds bare weight.
Utility tractors are the next heavier category, 7,000 to 10,000 pounds bare weight. Utility tractors have a Cat II or Cat III TPH.
Ag tractor are heavier than utility tractors. Equipped with Cat III, IV, V TPH. I do not know what the biggest ag tractors weigh, but the biggest have 600-horsepower engines and operate on tracks.
A Cat II hitch is heavier in weight and spreads wider. It is stronger so it can pull heavier/wider Cat II implements without sundering.
All tractor Three Point Hitches are primarily ***connection points*** which offer some adjustability to whatever implement is mounted. By keeping most implement adjustment on the tractor you only buy the adjustment paraphernalia once, with the new tractor, rather than repeatedly with every implement.
Yes. Cat II implements are wider and heavier. You pay for every implement pound.
Neither King Kong nor Godzilla feel power steering is essential.
It is difficult to maintain traction pushing an FEL bucket into dirt without 4-WD. With only 2-WD it is often difficult to fill the FEL bucket to capacity.
I assume that 20-30 year old tractors come with power steering?
Most, not all, twenty (20) year old tractors have reliable power steering.
Deere and Kubota have historically been tops for legacy parts. With all the current supply chain disruptions every tractor part supplier is about equally BAD. Low volume, slow turnover legacy parts can be breath-taking expensive.
Is there a RockAuto for tractors to your knowledge? No.
In good years, the last good year being 2018, the total market for new tractors in the USA is a minimal 300,000 units. Deere and Kubota combined had around 70% those 300,000 units in 2018. Twenty-five other tractor brands divided the 30% balance. You are stuck buying replacement parts from the manufacturer of your tractor.
Can you give your thoughts on hydro static vs gear terms of the trade off between longevity, maintenance/parts, and easy of operation with a loader or tiller.
HST transmissions visit dealers for repairs less often than clutch & gear tractors.
Clutch & gear tractors require considerably more operator finesse and operator physical stamina than HST transmissions.
Some tiller operation requires tractor progress at a slow walking pace. All HST transmissions can produce very slow wheel speeds.
Some gear tractors stall at low tiller operating speeds.
TBN ARCHIVE: HST vs clutch & gear tractors site:tractorbynet.com
/ First Tractor #26
About a year ago I bought a Yanmar YM2310 2WD tractor. It came with an FEL (Front End Loader). After the purchase I learned how hard it can be to find an FEL for an older tractor. And I am so glad my tractor has the FEL. So, if you want a tractor with a loader buy one with a loader. My tractor has, apparently, 23 HP at the PTO. I am using 5 foot wide Yanmar tiller with this tractor with no problems. The tractor easily pulls the tiller through virgin Western Washington glacial till. The tractor is now 42 years old.
I looked into PTO driven log splitters and watched videos of them and for me I wouldn't use one. They are as expensive or more expensive that gas powered splitters with the same capacity. I have also found that renting a big wood chipper is way cheaper than buying one so unless you need to do lots and lots of chipping a rental might be be the best option.
See this link: Yanmar Tractors — Fredricks Importing . They sell the 4wd version of my tractor for$7600.00. Fredricks is selling these older tractors refurbished. They have a good reputation but I have only done a limited amount of business with them. BTW, the price does not include the FEL. And like I said before, do not buy a tractor without an FEL if you want one. I can't imagine having a tractor without a front end loader because I find that front bucket so very useful.
Yanmar tractors like mine, which is a grey market tractor, nevertheless have a great reputation as reliable and tough machines. For many models there still available repair parts. Yanmar made a lot of John Deere machines and I think also supplied just engines for Deere machines.
My tractor has a Power Shift transmission. So the way this works is there is a 5 speed transmission that feeds the 3 speed plus reverse Power shift transmission. The 5 speed tranny requires the clutch to be pressed before shifting. The tractor must also be stationary. But the beauty of the power shift transmission is that there are internal clutches that work automatically so that you don't need to step on the clutch pedal to shift gears. You just move the shifter. And no clutch work going from forward to reverse either. This feature is super convenient when doing loader work. Super convenien. I cannot say enough good about how much easier it is to operate a tractor that has this type of system. I also have a Case 580CK backhoe with front end loader and it has a similar system called a Shuttle Shift. The Case system is just for going forward or backward and uses a torque converter but the end result is almost the same. No clutching when changing directions. Super super useful. On my tractor you can use the clutch with the power shift if you want to or need to but most of the time my foot stays off of the clutch pedal.
BTW, the 5 speed transmission in my tractor has 4 normal ranges and one range called "Creep". So even though it has 15 forward speeds, 5 speeds regular feeding 3 speeds Power Shift, it really only has 12 mostly used speeds. I have used the Creep speed a few times and it is VERY slow. A person can easily walk faster. But I have actually found it quite useful twice, so I'm glad it's there.
For the size of your acreage I would consider a tractor in the size range of my YM2310. I'm on 10 or 12 acres with a little more than 1/2 wooded and my tractor does fine. I am very happy with the size.
Cheers,
Eric
/ First Tractor #27
Ford 1520(HST)/1620 or 1920 with SSS. You'll find that power shift is out of your price range, but on small acreages it's too handy to pass on HST imo. My daughter lost her mind when I posted the 1620 for sale after the purchase of a 2910!
/ First Tractor #28
Most people here have probably refurbished an older tractor I personally owned two in my youth. Tires are expensive, parts can be a challenge and when you are done you have an old tractor with slow hydraulics that needs to be fixed everytime you use it. After trying that twice I bought a brand new JD 1070 compact with 39 hp, super hydraulics and 4wd in 1989. Sold it four years ago for almost what I paid for it. Great little tractor that cut, raked and baled hay, lifted more than it should have, and ran everytime I turned the key. Best decision I ever made and it cost me $5000 plus maintenance to own it for almost 30 years.
/ First Tractor #29
Thank you for the reply.
I should have specified a budget, ideally all in I would like to be under $10k (including some/all the attachments).
When I was looking for a truck I initially was going to go new. The prices were ridiculous, I chose rather to go old and sink the extra money into tools and materials to fix it up. I landed on a 2002 Chevy 1500 for $6500K and sunk $2000K into it to get it where I wanted it. I would like to do the same concept with a tractor. I value simplicity and longevity if I care for it.
It maybe what I'm after just doesn't exist and I'll need to adjust.
Ahahaha, deep breath, Ahahahaha. Dream on. Triple that. And no you can not buy used, everyone knows what they have, no low ballers.
/ First Tractor #30
I am looking for 4wd tractor with a loader.
  • Tiller
  • Wood splitter
  • Box blade
  • Wood chipper
I believe I need 20-25 HP at the PTO to run the tiller.
Eventually I may want to use other attachments so would prefer to not limit myself, but I don't have enough knowledge to know how to mitigate that.
I would prefer something old that can effectively/easily run a loader without custom work (welding up custom brackets, third party hydraulics, etc).
The reason I want to go with something old is price, I don't have $35K+ to drop.
Looking at you other response, at this time, I don't think your budget of <10K is really reasonable for everything you've listed - 2-3 years ago, maybe.
That said, think long & hard about the following:
1. At ~25hp, a 3pt wood chipper is going to be a small one, you might want to consider a stand-alone model - they are much cheaper than 3pt versions
2. Even cheaply or home made 3pt or front end hydraulic splitters are quite a bit more expensive than good quality used stand-alone splitters in the 25-30 ton range.
3. By dropping the two implements above and purchasing stand-alone versions, you "might" be able to find a really used tractor (without a FEL) with a small tiller & box blade within your budget. It will probably have some quirks/problems you will have to deal with.
4. If you are buying a really used tractor, consider your knowledge as a mechanic and all things tractor e.g., hydraulics, etc. If you don't have these skills (or know somebody that won't charge an arm & a leg for working on it) you might be better off Not pursuing a purchase.
5. Do you have the means to pick up a used tractor? Many people that have used tractors don't have a way to "deliver" or charge through the roof.
I hope I didn't burst your tractor bubble, but these are really questions that only you can answer.
/ First Tractor #31
if you were to buy all of that, as new - you would certainly blow your budget by double or more. (I needed New, for the features and for Operator ease-of-use, otherwise something used would have gotten me into a tractor years earlier.)
so, in my opinion get what you need for right now, first - tractor, loader. Then buy the other implements over time, as you come across them. Get a large enough tractor for your needs ... probably 35+ HP.
woodchipper - if PTO driven, bigger is better (25 HP tractors have limited options for the chippers) - I have a small tractor (Kubota BX23S) which is perfect for my needs. But now that I am looking for a wood chipper, I have all but ruled out the available PTO ones on something that is that limited. I want a chipper that can manage 3-5 inch pieces. The self powered chippers are better suited for me, PLUS the tractor is not then already committed for just that purpose.
You will always find something extra for the tractor to do, as you consider the tasks, so keep future goals in mind :)
enjoy the hunt, ... you'll pick a colour at some point
/ First Tractor #32
I am in the burn and save the money you'd spend on a chipper camp.
/ First Tractor #33
I bought a new 2017 Massey Ferguson 25 hp with FEL, Backhoe, 4x4, hydro hitch for $17500. you can find them without backhoe for around 12 to 14k
works great have 400 hr on it no issue look around on web for deals
/ First Tractor #34
That would be great.
I am NOT in the burn and save money camp, for the following reason ... where I live (interior BC) we Typically have burn restrictions for 5-7 months, ... and about 4-5 months of winter with 2 feet of snow.
The "burning window" is therefore, very short ... half of March, and perhaps October - November.
I'm saving for a decent WALLENSTEIN chipper, so that I can put the chips in the chicken run, or paths etc.
/ First Tractor #35
Bought a MF 245 2wd diesel for $850. Needed to major repair the engine and overhaul the hydraulic pump. At the time had between 3-4 thousand in it. Runs like a new tractor but looks like an old tractor. Year ago found a loader to fit for $2500. Yes needs the filled 55 gallon drum on the back for loader work. At this point and time believe I could sell it for a small profit, If I wanted to. But it is my keeper!
As suggested you might shop or even window shop at a few of these websites.
even may find a deal on craigslist or facebook marketplace, or even local classified ads.
My preference is MF as that is the dealer I worked for and learned them inside and out. but you have to know what you are comfortable with and don't forget the wife my have to approve the color!!
/ First Tractor #36
I'm also with you. Yes burning is "free", but it certainly still requires labor and often more time tending/stirring than just chipping and being done with it. I have limited time to get work done and I'm not waiting around for a good day to burn.
I have a woodmaxx Wm8m that I've run on both a new holland 1620 (28hp) and now a Massey 1740m (40hp). It's an amazing chipper and I 110% recommend it. However, running it with a 40hp tractor is completely different and I could never go back haha.
So I strongly recommend a 35-45hp tractor if you plan on chipping 3-5" material regularly. I also strongly recommend a power infeed chipper vs a gravity like the smaller wallensteins. It is sooooo much nicer to let it grab a branch and walk away.
/ First Tractor #37
all good points, and I overlooked the Good days, Bad days (wind etc) in my limited window. Thank you. I considered woodmaxx also, but I think the Canadian Mennonites are winning me over (Wallenstein) :)
/ First Tractor #38
Start by buying a good tractor, you can always add implements over time. I don't consider a loader an extra, get a tractor with a loader or you will be kicking yourself very soon after you don't. If you are worried about parts and implements, buy an orange, red, green or blue tractor. In other words stick with major brands that have dealers near you and support systems, especially if you are not mechanically inclined or just don't want to spend all your time searching the internet for out of production parts and equipment.
For $7k-10K you are going to be able to find a good 20 year old used tractor with a loader in the 20 to 30 hp range. The same $$ will get you a 20 year old used tractor in the 40 50 hp range without a loader. or a 30-40 year old with a loader. Here are a couple of good websites besides this one where you can do some research. Good Luck!
p.s. Also as a newbie, do all the research you can, read and search here and on the internet before you ask a string of easily answered questions. Everyone here is going to help you, but we expect you to do the homework too. Look it up, if you don't understand something then come here and ask for clarification and explanations. There are a ton of tractor geniuses here that are waiting to help. Also let us know what you end up with. Many of us answer question for people looking for advice and help and they never follow up with a post on how things ended up. We love when you tell us how it all worked out!
Welcome to the party!
/ First Tractor #39
It's easy to get lost in all of the recommendations and experienced opinions on a topic like this. You are probably realizing that a 10k budget will not go very far with the tractor, and certainly not with the implements.
My input would be to get out there shopping used and new. Sit on some machines. Talk to some owners, take what sellers may say with a grain of salt.
The comments on getting the tractor with a loader are spot on. Same with adding implements over time.
/ First Tractor #40
If I wanted a chipper I would purchase one of these
ROLLER Weldment for WC-8 Wood Chippers
SOLD BY SANKING 0 / 5
TPIN: CW8PJQHJ2Condition: New
Price:
$150.00
and fab the rest.
willy
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
Freightliner Columbia (A63689)
Freightliner...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
