First Time Owner - Transport Cart Question
   / First Time Owner - Transport Cart Question #1
Gryz
Yanmar SA424
Just took ownership of my first tractor for my small 2 acre lot in Pennsylvania - a Yanmar SA424. Only have the FEL and also got a posthole digger which I used to build a chicken run for my Fiancé but took it off when I was finished.
With nothing on the back, I am looking for a carrying cart of sorts that fits on the 3PH to carry tools and such. I have seen several iterations, the DIY with the CarryAll, the Titan Dump Box, and then the more expensive transport carts available in Europe.
I have searched YouTube and forums but have not seen this particular question asked. To save some money, can I not just use a 2" receiver like This and a 2" hitch cargo carrier like This?
If so, second question: how do you keep it from tilting when raising the 3PH? I would like it to stay level. My thought is the top link must be installed also level with the ground.
Thanks!
   / First Time Owner - Transport Cart Question #2
I’m not familiar with this particular tractor; but doesn’t it have a drawbar?
Hi, yes it does also have a drawbar.
   / First Time Owner - Transport Cart Question #4
If I'm understanding you, start with one of these:
CountyLine Carry All at Tractor Supply Co.
Generally in the sub $200 range at most farm and tractor type stores.
Add various bits of lumber, PVC pipe, angle iron and so on to meet your needs. At least a dozen threads here on different buildouts.
   / First Time Owner - Transport Cart Question #5
I misunderstood, I thought you wanted to hook up a cart.
Like Diggin it said; the tractor supply county line carryall is roughly $250 and I don’t think u would save much money trying to fabricate one given the cost of steel and welding rod.
I have one and find it very useful.
And yes the center link adjusts the level and your position control will ensure it does not go too high.
   / First Time Owner - Transport Cart Question #6
Thank you for the help. My concern with that is that the pins are up relatively high and would require it to be lifted just buzzing around the property. I thought maybe the 2" receiver and cargo carrier would sit a bit higher up.
Just to be clear, this is what I am talking about attaching.
   / First Time Owner - Transport Cart Question #9
Either one would work, but the type from TSC are far heavier duty.
With the receiver type, you will still have to lift the 3 point when moving. It will also be much looser in the mount, able to tilt / shift side to side at least a little bit.
71066 (A49346)
71066 (A49346)
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A49346)
2016 Toro...
2019 Ford F-550 V-Mac DTM70 Air Compressor Flatbed Truck (A48081)
2019 Ford F-550...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
