Hi, I intend to build a firewood processor. And I have a question... well I have many but one for now.
My processor will be working with the pto of my 80 hp tractor. I will put 2 pto pumps on the same shaft.
This kind of pump have a hole for the shaft that go through the pump.
and I will probably use a control flow valve. like this for example:
4/3 GPM Prince Priority Flow Divider w/Relief | Divider Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
To divide the flow. If I understand correctly, this kind of valve divide the flow in two: E.F Excess Flow and CF Control Flow.
My CF will go to the split wood conveyer . and the EF to another actuator, like the hydraulic saw for example.
My question, about this kind of valve is, do you know if the pressure change to the EF flow will increase or decrease the flow to the CF, or
if the CF flow can, under pressure, fluctuate. example the conveyer is free of wood, It receive 4 GPM and now it's full of wood and building
pressure and receive only 2-3 gpm?
Thank you
My english is not my first tongue.
Thank you
