Firewood processor help
/ Firewood processor help #41
I believe he is talking about a homemade cyl.
Not sure if that standard applies.
What went wrong with the first cyl.
had not time to mount the new cylinder..all afternoon trying to find an harvester bar..here in portugal that is not easy..find it and buy it..oregon solid harvester bar jet fit 18HX, 75cm, 0,80 gauge, .404 pitch chain, and a 12 tooth new sprocket..
i think is called inductive sensors..they detect metal through a magnetic field, sending an electrical signal..we can do whatever we want with this signal..in splitter cylinder case, when it almost reaches the full stroke, the given order is to retract..all moving parts have this inductive sensors, and in AUTOMATIC MODE, we can do whatever we want, so..automatic mode push the log foward, until it stops in lenght measure cylinder at the end (here there is another type of sensor to detect if the log is already there)..clamp go down, and cut fase begins..the cut log is push down with another cylinder, that have a sensor to tell the Beast it already can advance, because have wood to split! :)..when retraction begin, automatic mode push the log foward again, and so on..until the last cut..can´t put it automatic..didn't figure out how to do it..:(
well..don´t know if i can test the new cylinder with 11000 PSI!!!!!..what do you mean with "exploding cylinder"?!?!? explode means explode!?!?..
Yes, the two pumps will function exactly as you said! low pressure high volume, low volume high pressure!
nothing went wrong with it, J.J..it simply was not big enough, that is what was told in the shop..if this is not working, we have do make another one, bigger..:)
we already talk about this..i donエt think the problem was in the old cylinder, but..engineer does..
/ Firewood processor help #44
What's the diameter of the log in the video? I think you should be able to split that easily. Does it work good with pine or other type of wood? I think something is not set right with the dual pump valve.
400 mm..
we have split other eucalyptus diammeters, like 200mm or 300mm..but even this were to rought for me..maybe the high volume lo pressure pump is set to high?
/ Firewood processor help #46
I am not sure, I would say that the pressure to switch between pumps is not set right and it may cause interference between the two pumps.
/ Firewood processor help #47
I think I said this before but if it was me, I would only run the high pressure/low flow pump until you know everything works and then install the other pump and see if it still works. One pump eliminates many possible problems and lets you verify that this pump is set up properly.
Ken
/ Firewood processor help #48
I still have not seen an pressure figures when splitting, or even testing.
It is hard to believe that the old 6 in cyl or the new cyl would not split with a pressure of 3000 psi developed.
6 in cyl = 84,823 lbs, or 42 tons
7 in xyl = 115,453 lbs , or 56 ton
If your pumps have the capability and the cyl is working, you should be splitting any/all wood.
Show me some pressure with cyl stroke at max. Short video would be great.
/ Firewood processor help #49
What were the results in testing the new cyl.
we were not able to mount the cylinder today..we have got lots of problems with new harvester bar..have to rebuild almost all mount parts to properly fit the new 12 tooth sprocket and the chain lenght..and was not finished yet..:(..and, by my calculations, we will have about 160 ft/sec (witch is too much, i think), and only 104 in lbs of torque (think divided by 2, because we have 2:1 ratio pulleys)..so..i think torque will bee too poor..
maybe only on monday we will be testing the new cylinder..the weekend will be to rest..maybe at the beach..:)
/ Firewood processor help #51
All I can say after reading this and watching the video is what a mess. To many things wrong here to even start. First off, your 25hp electric motor isnt big enough to pump 30gpm of combined oil flow at 5000psi. Wont work, end of story. Then there is the issue of chain size and speed. To start with, chain speed should be double the 3150ft/min you are shooting for with the 3/8 chain. I havent checked any of your math, but the 5.7hp number you mentioned would make your hydraulic chain saw somewhere in the 50cc chainsaw size, but running at half speed. I think I will agree with your assessment that your saw isnt cutting like it should. Now on down in the thread you are swapping out a .404 pitch chain and going with a 12 tooth sprocket, good luck with that, it still wont work with your current hydraulic motor, pump pressures and flows. i think you also said you would be going with a different f11 motor, but you dont even have enough power to run the smaller motor so I dont think your changes are going to help. If you check the specs for a husquvarnia 3120 chainsaw, you will see that the saw makes 8.5hp, and if you have ever ran one of those saws, you will know that even with that much power, it still cuts slow using a .404 pitch chain. Chain speed is 5265ft/mi and it has 7.7nm/torque at 6000 engine rpms. f11 motors are high rpm low torque motors and require very high pressures to make power. You aint going to get there with what you have.
I am not going to comment on all the automatic stuff you have going on. My experience with automation is its a maintenance nightmare. Sounds simple enough, push a button and the work is done for you. Real life is someone will have to constantly babysit the machine and trouble shooting problems can take longer than just cranking up a chainsaw and grabbing a axe. I think you are building your machine off the wrong information and it might be time to step back and rethink your plans. A few changes I would make are using a bigger power supply, or downsizing the hydraulic requirement. I would also forget about using any of the f11 motors to build the saw. Yes they work wonderful, if you have the power to run them, (you dont), but because of their high pressure and flow requirments, they can add considerable cost to the machine. Not only in the actual cost of the F11 motor, but in high pressure pumps, valves, and hoses. Most of the processor manufacturers are using gear motors because they are simple and they work. They dont turn the rpms that f11 motors do, but they make tons more torque. Forget about motor rpms and concentrate on chain speed instead. Get your .404 chain speed up to around 6000ft/min and your saw hp up to around 10 or so. This can be done using a larger cuin gear motor (I suggest around a 2cuin motor) using more oil flow at lower pressures than with the f11motors. Also consider using a proportioning valve to split up your hydraulic pressures and flows so that your log clamp, saw cylinder and saw motor runs off one circuit. You can supply the proportioning valve with oil by using one of your solenoid valves to make it a "push a button" and let the valve do its thing. Set up properly it should clamp the log, start the saw and then lower the saw into the log and with using a pressure switch/or limiting switch, once the log is cut, it should just rise back up to wait on the next cut. Those valves run around $500 or so. Another thing I would consider is buying a actual 2 stage pump for your splitting cylinder. You can get a 28gpm 2stage pump and piggy back it off of your saw pump. This would eliminate at least one pump from your system and lower your hp requirements by a bunch. You can run this thru your solenoid valves and probably eliminate a few of those as well. Might take some trick wireing to get the solenoid valves to switch automaticly, but again limit switches and maybe a momentary switch, will do the trick. What else you running, a conveyor to feed the log, can be pulled off the saw circuit since you wont be advanceing a log and sawing at the same time, Just add another solenoid valve and subplate to that circuit, you are down to 3 solenoid valves and a few limit switches. Need a wedge cylinder circuit, and a live deck, just add a couple of more solenoid valve to your saw circuit because you wont be sawing and using those other actions at the same time anyways. Your down to 5 solenoid valves and two pumps and no longer have a need for the combining valve you must be using for the twin pump setup for the splitter cylinder. Looks like most of this stuff is already on your machine.
Just to add, if you go with a 2cuin or larger motor for your saw, you can get by with a lot less hydraulic pressure, around 1000psi or so. This will cut down on your engine hp requirements considerably, but your still going to need flow to get the speed you need. (I havent done the math, but figure on 20-25gpm). The 28gpm 2stage pump will require around 16hp, but using a electric motor that requirement is probably lower as well. My suggestions should get your hp requirement down into the range where you can use what you already have. Take the time to do the math or have someone do it for you before you start making wholesale changes to your machine.
first of all , I thank you for this all support, I can say that what you said is one of the few alternatives left me , and sure I'll use it..i know things are all mess up, but, at this stage this is what i have, and as soon as the new cylinder is ready, I will give the all circuit an opportunity to "say" something..
i Know from what i learn here in the past week (thank you all) that my 25 Hp wonエt run all my pumps at 5000 PSI at the same time..that 's for sure..
so..this is what i have, and this is how it will be working (if my math is correct), one thing at the time:
- 2 combined pumps will work like a 2 stage pump (donエt ask me how, all i know is that there is a proper valve to do this)
My 25 HP will pump 17,5 GPM at 2000 PSI giving to my splitter 25 TON (56000 lbs) of force, with a 8 seconds extend time.
My 12,5 GPM pump will work when eucalyptus pressure rise above 2000 PSI. My 25 HP at 3000 PSI (this pump can work at 4000 PSI, but i donエt have the HP needed) should push the cylinder up to 40 TON, more or less..
( I know that my second pump should have less displacement, to be able to work with more pressure, but, thats what i have for now)
- One 5,8 GPM pump for all the stuff..my 25 HP will handle it with no problems..
- One 8,9 GPM pump for saw and saw cylinder..since the saw cylinder will work with very low pressure and low speed, I estimate that the saw will work with around 8 GPM. So, my F11, with 0,31 cuin displacement, will turn the .404 pitch at around 9500 feet/min, because there is a 12 tooth sprocket and a pulley ratio of 2:1, waiting for the F11 exchange to a 0,62 cuin (this exchange will be taken by the hydraulic circuit company manufacter with no charge). With this new 0,62 cuin displacement, the 8 GPM at 2600 PSI (pump pressure limit) will turn the saw down to 5000 feet/min, and rise power to 12 HP, and 14 N.m (125 in lbf) of torque. Only 13,5 source HP needed..
(yes, i agree with you..better if more displacement was available, meaning more torque..)
..So..iエm waiting for the replace of the new cylinder, to see what happens, and then decide what to do..but I'm nervous , that's for sure..i think my second splitter pump should definitely have less displacement..dry eucalyptus is very hard wood..and my cut wonエt be good, think my math is not 100% correct..
Good afternoon!
New cylinder done and tested..
Donエt know really why the old one doesnエt splitt..all reliefs are exactly the same, the wedge is the same, we donエt touch anything else..
in the end there is a video where we can see the splitter pressure gauge..only 1000 PSI needed to splitt a 400 mm eucalyptus with this new 6,3 in bore cylinder..the 5 in bore old one shuts down the electric motor, because hight pressure required i think..and doesnエt splitt anything at all..
here is a link to some short youtube videos of today tests...
https://www.youtube.com/channel/UC8ytHMRLJEk-ggvRnnQdzoQ/videos
Today we gonna get the new F11-010 for the saw, and soon, i hope, i will post here some videos of the job donne..
/ Firewood processor help #54
Glad you figure it out and it seems to work just right! Something was wrong with the other cylinder.
/ Firewood processor help #55
You never did tell us the max pressure before going into relief.
You need that to figure the force as in tonnage.
/ Firewood processor help #56
Your figureing your chain speed wrong. Chain speed in fpm= chain pitchx2xnumber of teeth on sprocketxrpms/12, or .404x2=.808X12=9.696X5000rpms=48480ipm /12=4040fpm. Your chain speed is still to slow for the size chain you wish to run. Your saw will cut at that speed but its still running at 80% throttle. Using the smaller motor would get the chain speed up to a very useable level, but you will probably bogg the smaller motor down, especially with ony 2600psi.
My thoughts are that if the hydraulic company you bought the f11 motor is willing to do a swap for another f11motor, I would seriously consider swapping for a gear motor instead. you can take the difference in the price of a F11 and a gear motor and redo your hydraulic system to something that will work. Replace the twin gear pumps for your splitting circuit to a 28gpm 2 stage pump and probably still put money back in your pocket.
well, J.J, you are wright.. I only tell you the max pressure on block valve i ever seen (5000 PSI, and motor shutt off) with the old cylinder..i don´t know exactly what was the relief pressure, but I don´t think was lower than that, wright?..now I can´t measure it anymore since some parts were used to make this new cylinder..but i´m going to figure it out when we got the saw running, and automation donne..we will need to know both big pumps pressures to set the reliefs wright..i´m point to set the 17,5 GPM pump at 2000 PSI and the 12,5 GPM pump at 3000 PSI, since i have 25 HP of source power..
I will need one of those pressure gauges..
..but i'm starting to believe that the problem was a lack of splitting power..don´t forget that more 1,6 inches in cylinder bore diameter represents, at the same pressure, more 17 tonnes..well, that is something, don´t you think?
/ Firewood processor help #59
well..think size was the only thing was wrong with it..(?!?!?) :)
If you were reaching 5000psi with the other cylinder, and now you just reach 1000 psi with the same log, I would say that something was causing all that excessive pressure in the cylinder. I don't believe that the old cylinder could not split that wood. I have a 80 mm bore cylinder in my Log splitter that had already split logs even larger than the one you had, with something like 1500/2000 psi.
think we both have the same formula, because your result is "exactly" the same as mine..
..so..here we go with some math..4040 fpm is what i get when using a .404 pitch with 12 tooth sprocket at 5000 final rpms..i'm point to have, with my new F11-010, almost 6000 rpms with my pulleys, that will give me almost 5000 fpm in chain speed..i know, is not to much, but...i already got the new f11..by the way, it seems very nice and heavy one :)
..but this is the nice part..as I "speak", Iエm doing some excel math, and think I just find out one interesting thing..check my attachement..
..I think that bigger displacement will give you more torque, but less RPM..
You will have to add some pulleys or bigger sprocket trying to equal the rpms that lower displacement motors have..so, for the same amount of power supply, we will have the same (more or less) results at chain speed, torq and HP..check my math..try to mess around with flow (or instead use pulleys), pressure, and HP needed..View attachment cálculos diversos hidraulica equals.pdf
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
