Fire Pit Idea Needed
   / Fire Pit Idea Needed
Weeds, grass, elms are growing thru the fabric and under the pavers until they find light between the joints of the pavers. The fabric was used and I think that has made the problem worse but I also question if new fabric is better. We have to have pavers for chairs or they will sink in the ground after winter rains. (Ask some of my neighbors how I knowo_O) The surrounding grass is mown with a finishing bush hog and trimmed with a weed eater.
I'm considering biting the bullet and using hardpack.... I googled hardpack and it said "dirt, gravel or snow" What???. that was no help.
   / Fire Pit Idea Needed #12
Use lots of straight nitrogen fertilizer on the bricks. It will not make the bricks grow but will discourage any vegetation. Follow up by converting the soil under the bricks to a ph that is not conducive to growth.
   / Fire Pit Idea Needed #13
Weed fabric never really works in the long run as dirt will eventually fall in between the cracks in the pavers or what ever is over the weed fabric then seeds will grow. Keeping any area weed/plant free is going to be maintence unless its paved or has concrete over it.
They do make organic weed killers. One is called "burn out".
   / Fire Pit Idea Needed #14
If your want to kill everything growing between pavers, look up a DIY salt solution and pour it on the weeds/paver section.
   / Fire Pit Idea Needed #15
Grass will grow just about any place it finds a moist base that will support roots.
An effective means of killing the roots is heat. Build a fire and get your blocks/pavers warmed up and keep them that way. But a propane torch and burn the weeds and grass.
Use chemicals to kill the weeds and grass growing. Keeping them out of any area requires constant attention (otherwise know as maintenance). Pick your desired maintenance process and keep after it.
   / Fire Pit Idea Needed #16
Buy one of these: https://www.northerntool.com/shop/tools/product_200584784_200584784
Use it to start a fire instead of oil or gas dumped on the wood. Then heat the weeds between the pavers. You do not need to burn the weeds but heat them enough to kill them. Works well along my chain link fence. Much easier then a weed whacker.
   / Fire Pit Idea Needed #17
I put in a simple fire pit last fall consisting of a 12' x 12' array of pavers with 4' x 4' hole in the middle for the fire. It has been great to have the neighbors over for an evening around the pit. The land is flat, sufficiently far from trees and I put landscape fabric (used) down before l laid down the pavers. I wanted to keep it simple - no excavating, no gravel, no concrete. The result was a disaster - this spring grass and trees are growing between the pavers. Was the problem caused by using used fabric? Would new fabric prevent growth? I have considered thicker material - shower pan liner, roll asphalt roofing, pond liner - but I am running these alternatives on TBN to get your ideas because I do not want to experiment and have to do it again. Your ideas are welcome.
I used a large tractor rim surrounded by gravel. You can roundup any weeds that break through. If you are going to build wood fires, you need a pretty good circle of gravel to prevent fire. You'll have an easire time with chaires if you use crush and run.
   / Fire Pit Idea Needed #18
I have laid a lot of paver patios, never had a weed problem. you need a base. We compact 4" of 5/8minus gravel then scree 1" of coarse sand using 1" pipes and a 2x4. Do not compact the sand or walk on it after screed. lay the pavers then compact over top of the pavers with a plate compactor. Use plastic paver edging(easiest) or concrete around the outside of the perimeter to keep things in place. Lastly use polymeric sand in the cracks, sweep it in as much as possible and compact a few times to shake the sand into the joints and fully fill. It will set up almost like concrete but is still flexible, seeds can't get in and you will never get a weed problem. No underlayment is necessary, it really never works anyways. I know it sounds like a lot of work but really goes quick and will last as long or longer than a poured concrete pad, pavers will never crack like slabs.
a lot of the time the stuff coming through the cracks in poorly built patios is not from underneath, it is actually seeds that have blown in and started growing in the cracks.
   / Fire Pit Idea Needed #19
only use plastic. fabric just makes it harder to pull the weeds out.
   / Fire Pit Idea Needed #20
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2020 DRAGON ESP...
