Finish Mower vs Belly Mower
/ Finish Mower vs Belly Mower
With the droughts we have been having, our grass (lawn or pasture) tends to be dry unless it is after a rare rain storm.
/ Finish Mower vs Belly Mower #22
I sold my small ranch a few years ago and now an in the market for a subcompact utility tractor. My question is finish mower vs belly mower for 1 acre or so.
I am very familiar with rotary cutters or shredders. Since this will be for some lawn mowing, what are users experience with both.
I like the idea of being able to drop the finish mower when I am hauling stuff with tractor or doing other projects. My concern is dragging the belly mower when working on a backyard slope cleaning my wife’s chicken coops (she has over 150 egg laying hens). I would be hauling feed weekly from the front of our property up a slope to the barn.
I expect to till a garden and maybe dig some post holes.
The utility is why a finish mower appeals to me.
The brand of subcompact tractor is still open.
I had a kioti CS2410 subcompact with the mid mounted mower and it was simply awesome. But I found it to be a little small for loader work so I bought a compact kioti CX2510, again with a mid mounted mower. The bigger tractor is much more capable than the subcompact was. Close to Twice the hydraulic flow for anything you may use that for like a wood splitter or grapple, 1100 pounds of loader lift instead of 700, Suspension seat, tilt steering etc.
If you are planning on a post hole auger attachment, the compact would handle that work better I think as well.
I've owned a kioti since 2013 and have had a great experience owning one.
/ Finish Mower vs Belly Mower #23
I've had both, issue with the belly was taking it off / on, on the Kubota BX it was a Pain, had to lift the front end to disengage the PTO, if you did not have garage / hard surface it was not a pleasant task. The rear finish on the Kioti eliminated the frustration of attachment, once I got use to it, it was very easy to maneuver, easily did everything the belly did, one of the greatest advantages of the rear was the difference of the dust / dirt, I like an open cab having the cutter in the rear was a lot cleaner up front. The rear allowed quick disengagement and easy maintenance. The final decision would have to be based on lawn obstructions / challenges for movability.
/ Finish Mower vs Belly Mower #24
For @ the same money you can buy a ZTR. One thing you need to under stand if you have a loader on the tractor it will be in the way when mowing in tight places. From experience you would be happier with a separate mover then having it as an attachment to the tractor.
/ Finish Mower vs Belly Mower #25
All good info. Lots of hours of experience in the previous posts. I will only add this: I opted for a craigslist find of a 3pt hitch finish mower [LandPride] and have never once missed the belly mower my previous Massey had. This mower has survived a couple tractors and is very easy to use/maintain. I have had little issues with maneuverability on my [currrent] Mahindra 2645. The mower is right side discharge. But I have always used a push mower to do trim work [I can use the walk]. COnsequently, I have NEVER taken the loader off for mowing.
Good luck with your choice and I hope you find our opinions helpful.
/ Finish Mower vs Belly Mower #26
I have a 72" belly mower on a Kubota tractor. It beats a 3-point finish mower in every way. I can drop it and connect it in 5 minutes easily. It doesn't swing around behind the tractor with every turn. It's built like a tank and can handle anything you need to mow. Most maneuvarable mowing option for a tractor accessory. Also, very easy to work on and access due to ability to remove it and just lift it up with the loader.
I wouldn't even consider using a 3-point mower behind that same tractor. I can't think of a single advantage to a rear mower.
Having said all that, I'd recommend getting a zero turn mower to mow your lawn. It's ready to go whenever you need it and does a better, faster job. A small tractor with a beefy mower can be really handy, especially for large wide open areas. But for weekly mowing of an acre around your house, get a zero turn.
The newer Kubota mowers go on and off pretty quickly. I've never been overly impressed with the rear-mounted finish mowers, especially on uneven ground.
/ Finish Mower vs Belly Mower #27
I agree with CH4Ohio Get a dedicated zero-turn mower for your lawn. I’m 67, and it’s getting harder for me to connect my belly mower on my Kubota. I’m seriously considering buying a zero-turn for my 3-acre lawn.
/ Finish Mower vs Belly Mower #28
Mowing our rough hillside property a rear finishing mower works best. Can back under trees, up/down banks, creek banks that other mowers can’t touch. Rugged and easy to service. Being 3pt can raise and do FEL work. Wife is comfortable doing most of the mowing.
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
MASSEY FERGUSON 2605 TRACTOR (A60430)
MASSEY FERGUSON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
UNUSED INDUSTRIAS AMERICA EASY MAN TREE & POST (A60432)
UNUSED INDUSTRIAS...
2013 JLG G6-42A TELESCOPIC FORKLIFT (A60429)
2013 JLG G6-42A...
