- Joined
- Aug 31, 2001
- Messages
- 65,834
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Re: Finish Blade test - qualified success
I think the load is a much bigger factor than the hydraulic cooler. While the blocked oil cooler is a significant cause of heat, I'll bet that if you clean it out and run it on a concrete driveway for a while, with and without the multiple blades, and the deck at the same height for each test, the heat will be much higher with multiple blades. The only experience that I have to back this up is an excercise bike with a big fan in it instead of a wheel. The faster you turn the fan the harder it is to pedal. And there was a significant difference in horse(David) power required to get even one more mph out of that thing.
I still think that if you double the number of blades, you are doubling the required power to push them through the air, or at least very close to doubling it.
However you have more experience in this area than me, with the boats and planes and such. Is my thinking correct or is the hydraulic cooler more important?
