Grading Finish Blade test - the blades
   / Finish Blade test - the blades
Re: Finish Blade test
John:
I'll be interested to hear how they do on shorter grass. I've generally cut over four feet width of new grass each passs, and often over five feet, so most of mine is essentially single pass. Your multiple pass coverage presumably avoids the possibility of the right-side stripe. I hope it doesn't reappear in the shorter stuff.
It sounds as if the offset on my blades isn't needed with the deflector off. How high did you have the deck set for the cut in the picture?
When you get a chance, post a picture of the blade(s). Since they are reversible, I assume you center drilled them. How thick are they?
   / Finish Blade test - the blades #42
Charlie:
<font color=red>I'll be interested to hear how they do on shorter grass. I've generally cut over four feet width of new grass each passs, and often over five feet, so most of mine is essentially single pass. Your multiple pass coverage presumably avoids the possibility of the right-side stripe. I hope it doesn't reappear in the shorter stuff.</font color=red>
Well, it still stripes if the right side blades pack. but the next pass cleans it right up, much better than the roughcut blades do. A brief test tonight leads me to believe counterclockwise might pack the blades less. It'll cut a couple of inches off, full width, full speed ahead with no stripe. Overall this seems the best setup yet, for both lawn mowing and for my heavy field mowing.
<font color=red>It sounds as if the offset on my blades isn't needed with the deflector off.</font color=red>
No. In fact I think the offset was letting too much wind (and chaff) escape under the skirt.
<font color=red>How high did you have the deck set for the cut in the picture?</font color=red>
One hole down for rear wheels, 4 spacers down for fronts.
<font color=red>When you get a chance, post a picture of the blade(s).</font color=red>
Attached. With the twist these blades are cutting probably 1/2 inch or so lower than the stock roughcuts. Note the "swept tracks" on the bottom of the deck. I must have a close look at them to see what they might tell us about what is happening under there.
<font color=red>Since they are reversible, I assume you center drilled them. How thick are they?</font color=red>
1/8 inch thick. They are cheapies from Home Depot. Box has a Scotts label & says "22 inch Reversible Double Edged Blade".
Soon as I finish mowing the test plot I'll mail them to you for further testing.
John
   / Finish Blade test - the blades #43
<font color=red>Note the "swept tracks" on the bottom of the deck. I must have a close look at them to see what they might tell us about what is happening under there.</font color=red>
Here's a picture of the bottom of the deck after mowing grass and 12 inch weeds for an hour or so. later I went out and finished mowing my test plot which swept the bottom of the deck clean except for just a bit of stuff left around the stump jumpers. Not much to be learned here I guess, the 'swept tracks" are pretty uniform.
BTW, I noticed this morning that I blew the right rear tire on the mower last night. Yeah, the foam filled one. Spun it on the rim and chewed up the beads.
Charlie, I have one small area I want to touch up this weekend (it the blown tire will function well enough) and then I'll mail these blades off to you. And return your custom blades too. John
John:
No rush sending stuff down here. I'm leaving Thursday to drive to Wyoming. Be back the end of the month, so will be doing nothing on the PT 'til September.
   / Finish Blade test - the blades #45
Charlie:
<font color=red>...so will be doing nothing on the PT 'til September.</font color=red>
September it is.
John
This should be post 2998, right?
Resurrecting an old thread. Yesterday I did some comparison testing of blades that John Coxon and I have cobbled up for the 72" rough-cut mower. The PT blades are 3/8" thick, with two swinging on 1" bushings on each of the three stump jumpers. John has had some clogging problems, and both uf us have had a stripe left sometimes on the right side. We've adapted available mower blades to the decks to see if it improves things. I have been trying for a better finish cut, and John for faster cuts in rough stuff, and better clearance of cut grass from the deck.
Results: Both John's 1/8 thick blades and my 1/4" do better finish cuts than the PT rough-cut blades, with the deck low. Both have more lift than the PT rough cuts. When I raised the deck, I expected even better performance, because I thought there was a problem getting air out from under. The cut was significantly rougher, with more tufts uncut, and the right side stripe returning. The cutting, surprisingly, was better when the grass was so high and thick that it choked the mower and occasionally I had to stop to let it spit out a clump. (Despite the drought, we had over an inch of rain two days before the cutting. The grass was extremely heavy and up to 18" high in spots. Neglected pasture /w3tcompact/icons/smile.gif)
Conclusion:
1. John's blades are lighter, and a bit more prone to damage, since they are thinner and sloped downward at the cutting edge, but are reversible, and ultimately will be less expensive than mine. His are from generic lawnmower blades, mine from a gravely hardened set. In similar conditions, it is difficult to see a difference in cut quality.
2. Both sets are significantly better than the factory "finish" blades, which are prone to damage.
3. Both give a more even cut and fewer missed spots with the deck low, even in heavy thick pasture grass. Unfortunately, it's lower than I want to cut the pastures.
3. The rough cut deck will never be as good at finish mowing as a true finish mower, and not as good at cutting trees as a true brush hog. With the factory rough cut blades, however, it does a good job on underbrush, and with either John's or my blades, it does well for pasture cutting. I still need to do a little more testing with deck height and cant to find optimum smoothness.
Tonight, I will give John's a final test, this time on a lawn with only 10 days growth, and the deck set as low as I can get it.
Then -- the 100 hour service.
   / Finish Blade test - the blades #47
Charlie,
When all is said and done, will the final product be going back to PT for they’re manufacturing and distributing? Or will your blades be made available to PT owners?
PJ
   / Finish Blade test - the blades #48
Charlie, this may be our next trip ... Tazwell ..... and no hunting this year .... hahahahaha!
Last night, I lowered the 72" deck as low as I could get it, and cut my lawn with Sedgewood's blades. The results were great. I had been working on the belief that we had to get the deck up, for air flow underneath with high-lift blades. John's were higher lift than the ones I made, but I had the deck all the way down, and the evenness and smoothness of the cut was as good as I have seen with any mower on my lawn. (It scalped a bit, becasue 72" is too big, but that isn't the deck's fault.)
Bubenberg will chew me out for cutting grass that short, but if the grass survives, the cut quality is better than with the deck higher. It looks as good as my otherwise neglected lawn can.
<font color=red>will the final product be going back to PT for they’re manufacturing and distributing? Or will your blades be made available to PT owners?</font color=red>
Paul: I think PT checks this board now and then, and I have talked to Terry about the blades. I hope some time in the next few months to go to Tazewell, and will discuss John's and my tests with them. My hope is they will offer a replacement for the "finish" blades, and perhaps a thinner, higher lift set of rough cut blades. I hope they have been doing some development, as well, but haven't talked to them about it.
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
gravely riding mower (A55758)
gravely riding...
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
2003 Big Tex 10PI...
