Finally got a photo
/ Finally got a photo #1
Mace
Utah
YM1500D
I had two major achievemnts this week. First I got the wife on the new YM1500D. Second, I finally got a picture of it to post. I have been extremely happy with it thus far. I have put about 75 hours on it without so much as a hiccup. I know my shovel and wheelbarrow miss me, but I'm just cold hearted I guess - I just don't miss them......
No. It's not new. According to the info I can find it is somewhere between a '75 to '79. I put together a package with the tractor, FEL, PHD and box blade for $8500. That included shipping from Texas to Utah.
/ Finally got a photo #4
Mace that is some nice background you picked to display your tractor on. nice tractor. Glad it is working well and hope you enjoy your maching as much as I have mine.
/ Finally got a photo #5
Does SHE know you posted the picture?
Eugene
Thanks Normmm. It is a pretty little valley we live in. On the edge of the Great Basin. Very very dry this year. I know the folks back east would be happy with a dry year, but being on the local VFD the grass fires have kept us hoppin'.
/ Finally got a photo #7
Nice tractor Mace. You should find a year of manufacture stamped on your rear wheels.
Bruce
I didn't know the year was anywhere...Thanks. I'll have to look for it.
/ Finally got a photo #9
I couldn't find it on my 1510. I will investigate more tomorrow though. I'm curious. I know it was made from '79 to '81 though.
/ Finally got a photo #10
If your rear wheels are turned out it might be on the inside. Mine has it on the front and rears though so I was able to find it pretty easily (9/93)
Speaking of wheels.....how easy is it to put wider back tires on a 1500D?
/ Finally got a photo #12
Mace,
Wider isn't a problem. The problem is finding wider tires that fit your wheels AND maintain the rolling circumference of the rice tires that are currently on it. Being that it is 4WD you have to maintain a 3-5% ratio between the two axles ratios and that of the tires. The way I understand it you want the front wheels to turn 3-5% faster (farther) than the rears in order to take advantage of the 4WD.
Otherwise, if you can't find replacement rears to meet that criteria, you will have to replace the fronts and rears to maintain you ratio.
HTH
/ Finally got a photo #13
That is all you really can know. Find a date on you rims and you'll know when your rims were made. The odds of the same rims going on a unit that came off it in Japan is inversely proportional to the number of units in the load (or loads) that take that size tire. If there are five 1510s on the 2 containers we unload in a day or two before any assembly takes place, the odds of any given tire getting back on the 1510 it came off of is 1 in 5. It gets worse when there are other models in the load(s) that take the same size rim/tire.
And that is assuming the supplier ships the same wheels that came off the units, rather than just shipping x number of wheels to fit the units that make up the load. And assuming the yard that had it, and the farmer before that, never changed a wheel with another unit, or replaced a wheel.
So if I replace the front wheels and the back at the same time that sounds like the easiest way to go. It seems to me that wider tires would do better in mud and snow. Is that true?
/ Finally got a photo #15
All the parts on my tractor were numbered to the tractor itself: Wheels, muffler, lift arms, seat, etc. I've seen cases where a narrower tire did better in mud and snow because they would cut through to the hard pack, rather than ride on top and slip.
Bruce
/ Finally got a photo #16
Maybe.... Keep in mind that with a wider contact patch, that the tractors weight is spread out more and the actual weight psi will go down possibly lessening traction in loose ground.. It really depends on your particular mud(no experience with snow) as to if it would be better to sink down to hard ground or float across it.. I tend to think that a wide tire(light tractor) would be a bad thing for a tractor application..
/ Finally got a photo #17
I would have to think that tractors would be similar to trucks for tire width. If you want the tire to dig in, you want a narrow tire. The only people who use a wide tire for off road are ones who regularly drive on sand. A narrow tire should work better for both mud and snow.
/ Finally got a photo #18
Old Allis-Chalmers D-14s and D-17s were awesome pulling tractors in stock configuration. Once buried an F250 to the rear axle housing in mud...a farmer with a stock D-14 pulled me out backwards. Tall, relatively narrow tires. Way tall. More tall than narrow. He told me going in that the tractor would walk right out with my truck...he knew what kind of traction it would get.
/ Finally got a photo #19
Mace
Your tractor was raised in the mud. That is what the rice tires were designed for. With the 4wd you should get very good pulling from your tractor. More weight will help more than wide tires.
OK. You all convinced me that narrow tires are better. A friend at work told me that my tractor is too small to put liquid in the tires. He said that he thought I would loose torque because the engine is too small. Of course, he also said that he never had that small a tractor....
With snow and mud would I be better off putting liquid in the tires, or should I just leave well enough alone?
1988 FONTAINE 45' STEP DECK LOADER TRAILER (A60736)
1988 FONTAINE 45'...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
USC Series 2000 Conveyor (A61307)
USC Series 2000...
2025 D39 Hydraulic Trencher Mini Skid Steer Attachment (A61567)
2025 D39 Hydraulic...
3 Door Commercial Refrigerator (A60352)
3 Door Commercial...
